Seite 45 von 46 ErsteErste ... 3543444546 LetzteLetzte
Ergebnis 441 bis 450 von 459
Thema: Der x265-Encoder entwickelt sich...
  1. #441
    Erklär-Bär Avatar von LigH
    Registriert seit
    19. April 2003
    Ort
    OPAL-Invalidengebiet Altmark
    Alter
    42
    Beiträge
    42.719
    Standard AW: Der x265-Encoder entwickelt sich...
    Frohe Weihnachten vom Multicoreware-Team:
    Zitat Zitat von Pradeep
    x265 version 2.2 has been released. This release contains new algorithms to limit the search of optimal transform units, a new motion search method, and optimizations to the bitstream. With this release, x265 also supports POWERPC platforms, with key functions optimized by using ALTIVEC kernels.
    The latest version can be downloaded from here (MD5 sum = 36161843a70e4d46af1fa38cf221d0f3). Full documentation is available at https://x265.readthedocs.io/en/stable/.
    Release Notes for 2.2
    Encoder enhancements
    1. Enhancements to TU selection algorithm with early-outs for improved speed; use --limit-tu to exercise.
    2. New motion search method SEA (Successive Elimination Algorithm) supported now as –me 4
    3. Bit-stream optimizations to improve fields in PPS and SPS for bit-rate savings through --[no-]opt-qp-pps, --[no-]opt-ref-list-length-pps, and --[no-]multi-pass-opt-rps.
    4. Enabled using VBV constraints when encoding without WPP.
    5. All param options dumped in SEI packet in bitstream when info selected.
    6. x265 now supports POWERPC-based systems. Several key functions also have optimized ALTIVEC kernels.
    API changes
    1. Options to disable SEI and optional-VUI messages from bitstream made more descriptive.
    2. New option --scenecut-bias to enable controlling bias to mark scene-cuts via cli.
    3. Support mono and mono16 color spaces for y4m input.
    4. --min-cu-size of 64 no-longer supported for reasons of visual quality (was crashing earlier anyways.)
    5. API for CSV now expects version string for better integration of x265 into other applications.
    Bug fixes
    1. Several fixes to slice-based encoding.
    2. --log2-max-poc-lsb‘s range limited according to HEVC spec.
    3. Restrict MVs to within legal boundaries when encoding.
    Enjoy!
    Pradeep.
    Frisch compilierte Version "merge with stable milestone":
    x265 2.2+2-998d4520d1cf
    Auf gute Zusammenarbeit:
  2. #442
    Registriert seit
    19. April 2003
    Ort
    Alter
    42
    Beiträge
    42.719
    Kürzlich hat BEAMR, ein Mitbewerber auf dem Markt der HEVC-Encoder, sich mit x265 verglichen und behauptet, mit dem eigenen HEVC-Encoder in Version 5 sowohl schneller als auch besser zu sein:
    The Need for Speed: x265 & Beamr 5 Epic Face Off
    Wenig überraschend lief es laut folgender Analyse, soweit das ohne eigene Kopie von Beamr 5 möglich war, offenbar nur auf einer handverlesenen Auswahl von Hardware und Software-Parametern sowie Screenshots bestimmter Frames so scheinbar vorteilhaft.
    Tom Vaughan (Chefentwickler des x265-Projektes bei bei Multicoreware) hat diesen "Vergleich" mal ordentlich zerpflückt:
    Beamr compares their HEVC encoder to x265
    "Epic burn"? ... You decide.
    Geändert von LigH (11. September 2017 um 20:56 Uhr)
  3. #443
    Registriert seit
    19. April 2003
    Ort
    Alter
    42
    Beiträge
    42.719
    Demnächst wird es auch Unterstützung für Visual Studio 2017 geben.
    Ich hoffe, auch eine Unterstützung einer MSYS2-Umgebung wie in der MABS ist möglich. Hier hatte ich Probleme mit der Anpassung der Cross Compilation Toolchain. Bisher compiliere ich abwechselnd unter MinGW32 und MinGW64.
  4. #444
    König Avatar von Massaguana
    Registriert seit
    10. April 2004
    Beiträge
    988
    Nutzt x265 die Intel CPU Erweiterung AVX512? Also Profitiert x265 von einem Intel CPU im Vergleich zu einem AMD Treadripper?
     MacPro 5,1 | 12 x 3,06 Ghz | 64 GB Ram | 480GB PCIe SSD OWC Accelsior E2 | 12 TB HD
  5. #445
    Registriert seit
    19. April 2003
    Ort
    Alter
    42
    Beiträge
    42.719
    Geplant ist die Unterstützung von AVX512 durchaus. Bisher sehe ich aber maximal für AVX2 optimierte Assembler-Routinen.
    AMD-CPUs der Ryzen-Familie haben derzeit eher den Nachteil, dass aufgrund ihrer CCX-Architektur (CPU Complex) nicht alle Kerne unabhängig voneinander gleich effizient arbeiten, sondern bevorzugt Kerne eines CCX untereinander. Applikationen mit sehr hoher Parallelisierung könnten dann wohl die CPU besser auslasten, wenn sie dieses Detail in der Aufteilung der Threads berücksichtigen, nehme ich an (vielleicht so was wie NUMA Sub-Threadpools)... aber was weiß ich schon.
  6. #446
    Registriert seit
    19. April 2003
    Ort
    Alter
    42
    Beiträge
    42.719
    Es ist soweit...
    307 Patches mit Assembler-Code zur Unterstützung von AVX-512 (und anderen Optimierungen) wurden in die Entwickler-Mailingliste hochgeladen. Wird wohl ein Weilchen dauern, das alles zu sichten.
  7. #447
    . Avatar von Selur
    Registriert seit
    19. April 2003
    Ort
    underground
    Beiträge
    24.840
    Sichten, eventuellen CodingStyle anpassen, tests fahren,.. yup das könnte etwas dauern.
    Hybrid hier im Board, Homepage (www.selur.de), Forum
  8. #448
    Registriert seit
    10. April 2004
    Beiträge
    988
    Dann haben wir ja noch zeit und ein passenden CPU zuzulegen...
  9. #449
    . Avatar von Selur
    Registriert seit
    19. April 2003
    Ort
    underground
    Beiträge
    24.840
    + erst mal auf ein paar Berichte warten wie viel Performance das im Endeffekt wirklich bringt beim normalen Encoden.
  10. #450
    Tripel-As
    Registriert seit
    5. March 2009
    Beiträge
    233
    Gibt es denn momentan eine "preiswerte" Consumer CPU, die AVX-512 beherrscht und nicht von Meltdown/Spectre (was ja zu Performance Verlusten führt) betroffen ist?
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Prodisc entwickelt 4.9GB Rohling
    Von QuiCo im Forum News
    Antworten: 2
    Letzter Beitrag: 21. August 2005, 13:05
  2. BBC entwickelt Open-Source-Video-Codec
    Von rasta21 im Forum News
    Antworten: 12
    Letzter Beitrag: 3. August 2005, 11:38
  3. Antworten: 1
    Letzter Beitrag: 30. May 2005, 20:37
  4. Antworten: 0
    Letzter Beitrag: 4. April 2005, 18:36
  5. Cinema Craft Encoder killt sich
    Von Mongospliff im Forum DVD2SVCD und allgemeine (S)VCD
    Antworten: 15
    Letzter Beitrag: 20. February 2005, 00:27
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
