Seite 2 von 17 ErsteErste 123412 ... LetzteLetzte
Ergebnis 11 bis 20 von 161
Thema: MediaInfo - OpenSource-Analysetool
  1. #11
    Der mit dem Pinguin tanzt Avatar von Henrik
    Registriert seit
    28. November 2003
    Ort
    /home
    Beiträge
    3.332
    Standard AW: MediaInfo - OpenSource-Analysetool
    Henrik
    Arch Linux
  2. #12
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.7.4.7
    Homepage
  3. #13
    Registriert seit
    28. November 2003
    Ort
    /home
    Beiträge
    3.332
    0.7.5.0
    MediaInfo
    Henrik
    Arch Linux
  4. #14
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    Version 0.7.5.8, 2008-02-01
    + Matroska: Full parsing of DivX/XviD/H264/AVC settings (profile...)
    + AVI: Full parsing of AVC settings (profile...)
    + AVI: Added a tag "OpenDML" (for example, the PlayStation 3 doesn't support OpenDML files)
    + AVC: Framerate, Interlacement, writing library (only for eavc, x264 and MainConcept encoders)
    + TwinVQ : channels, bitrate and sampling rate
    + Musepack SV8 support
    + Musepack and Musepack SV8: tags support
    + AIFF and AIFC format support
    + MIDI format detection
    + FLV: FrameRate even if the tag is not in the header
    + AU/SND audio formats support
    + Vodei encrypted AVI files detection
    + Linux/MacOS: support of 2GiB+ files
    + FLV: Video parsing even if the container says there is no video
    x APE Tags v1 are detected again
    x MPEG-PS: some malformed files were not well parsed, fixed
    x AVC: Cropping was not well handled (example: height was 1088 instead of 1080)
    Download
  5. #15
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    Version 0.7.5.9, 2008-02-08
    + Lithuanian translation
    + AVC: CABAC detection
    + #1886241: AVC: all SEI userdata infos from x264/eavc in Writing library settings
    + ADPCM: compagny which created the stream is now shown in the codec section
    + PCM: precision about Little/Big endianess, Integer/Floating point method
    + #1882691: AC3+: raw files are now detected
    x AVC: FPS were sometimes 2x the reality
    x RealMedia parser was brocken
    x FLV parser was crashing
    x FLV: Better detection of Nellymoser audio
    x FLV: Disabling Framerate estimation if a VFR file is detected (estimation was false in this case)
    x Better false-positive MP3 detection (NSV files are no more detected as MP3)
    x IFO: there was a mistake betwwen NTSC and PAL framerates
    x Win9X support was (again) brocken in 0.7.5.8
    Download
  6. #16
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    MediaInfo: 0.7.6.0
    In this release: RMP3 and Id3v2.2 support, better detection of Lame encoder (MP3), and few bug fixes.
    Download
  7. #17
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    MediaInfo 0.7.6.1
    Changes:
    + Lithuanian translation updated
    + AC3: TrueHD detection
    + MPEG-TS (or Bluray): VC-1, AC3+ and AC3 TrueHD detection
    + AVC in MKV: all SEI userdata infos from x264/eavc in Writing library settings
    + EVO: Better detection of duration
    + Dirac: raw files parsing
    + MPEG-TS: Dirac management
    + MPEG-TS: DVB subtitles/Teletext management
    x MPEG-4 Visual (DivX/XviD): writing library name was missing
    x MPEG-Video: some DTS files with wrong extension were detected as MPEG-Video
    x SWF: Compressed SWF files support is back
  8. #18
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    MediaInfo 0.7.6.2
    Changes:
    Version 0.7.6.2, 2008-03-28
    + Spanish translation updated
    + The ToolTip text is now a summary (instead of a complete list)
    + MKV: handling of files created for streaming
    + MPEG-4: Handling of corrupted stream size info with some PCM streams
    + DVD video: Hebrew patch ("iw" code is mapped to Hebrew)
    x MPEG-4: better handling of bitrate mode (VBR or CBR)
    x AVI: MediaInfo reads now the framerate value from the container rather than the stream value
  9. #19
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    MediaInfo 0.7.6.3
    + Portuguese (Brazil) translation added (Software and website)
    + Thai translation added (Software and website)
    + AVC: Count of reference frames
    + AU: Comments
    + Some global speed improvement
    x #1931844, Id3v2: Unsynchronized frames support (v2.3 & v2.4)
  10. #20
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    MediaInfo 0.7.6.4
    + About the library : Java/Linux binding is available
    + DV (raw) files support
    + Better support of DV in AVI container (type 1 and 2)
    + AVC: Handling of SEI which is before a SPS
    + AVC in AVI: reading more info (Profile, Cabac...) from streams created by FFMpeg
    + Vorbis in AVI: reading more info (Max bitrate, tags...) from streams created by FFMpeg
    + Detection of VC-1 in MPEG-TS from MainConcept encoder
    + MediaInfoLib is now thread-safe
    x #1943743, AVI with MPEG-Audio VBR and delay: delay was incorrect
    x Pixel Aspect Ratio was sometimes inverted (1/x)
    x XviD CodecID was redirected on Koepi website, no more available, changed to official XviD webpage
    x #1946098, DV in AVI: DV aspect ratio errors
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Wie Quelltexte von OpenSource-Projekten compilieren?
    Von Fr_An im Forum Software-Entwicklung
    Antworten: 73
    Letzter Beitrag: 16. July 2006, 10:16
  2. Ein Koenigreich fuer OpenSource
    Von scharfis_brain im Forum Talk im Turm
    Antworten: 37
    Letzter Beitrag: 11. December 2005, 10:20
  3. OpenSource gegen kommerzielle Hersteller
    Von DerEineRing im Forum Talk im Turm
    Antworten: 20
    Letzter Beitrag: 16. May 2005, 17:32
  4. Kommerzielle Vermarkung von OpenSource-Software
    Antworten: 15
    Letzter Beitrag: 22. April 2005, 20:02
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
