Code:
Environment
StaxRip version: 1.1.7.2
OS Name : Windows 7 Home Premium
OS Version : 6.1.7601.65536
OS Type : 64-bit
OS Culture : German (Germany)
.NET
v2.0.50727 : 2.0.50727.5420
v2.0.50727\1031 : 2.0.50727.5420
v3.0 : 3.0.30729.5420
v3.5 : 3.5.30729.5420
v3.5\1031 : 3.5.30729.5420
v4\Client : 4.0.30319
v4\Full : 4.0.30319
Source file MediaInfo
C:\Users\Exilit\Desktop\qdqd.avi
General
Complete name : C:\Users\Exilit\Desktop\qdqd.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 3.28 GiB
Duration : 42s 67ms
Overall bit rate : 670 Mbps
TCOD : 5910333333
TCDO : 6330999999
Video
Format : RGB
Codec ID : 0x00000000
Codec ID/Info : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
Duration : 42s 67ms
Bit rate : 664 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Bit depth : 8 bits
Bits/(Pixel*Frame) : 24.000
Stream size : 3.25 GiB (99%)
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 42s 67ms
Bit rate mode : Constant
Bit rate : 6 144 Kbps
Channel(s) : 2 channels
Sampling rate : 192 KHz
Bit depth : 16 bits
Stream size : 30.8 MiB (1%)
Interleave, duration : 249 ms (7.47 video frames)
Interleave, preload duration : 250 ms
Demux AVI using VirtualDubMod
Demuxer: Demux AVI
"D:\StaxRip\Applications\VirtualDubMod\VirtualDubMod.exe" /s"C:\Users\Exilit\Desktop\qdqd temp files\qdqd_Demux.vcf" /x
Source Macros
Source Directory: C:\Users\Exilit\Desktop\
Source Directory Name: Desktop
Source Directory Parent: C:\Users\Exilit\
Source File Path: C:\Users\Exilit\Desktop\qdqd.avi
Source Files Blank: "C:\Users\Exilit\Desktop\qdqd.avi"
Source Files Comma: "C:\Users\Exilit\Desktop\qdqd.avi"
Source Framerate: 30.00
Source Framerate MediaInfo: 30.000
Source Frames: 1262
Source Image Height: 720
Source File Name: qdqd
Source Seconds: 42
Source Image Width: 1280
AviSynth Filters
AVISource("C:\Users\Exilit\Desktop\qdqd.avi", audio=false)
Crop(0,0, -Width % 8,-Height % 8)
ConvertToYV12()
AssumeFPS(30, 1, true)
Audio Source File MediaInfo
General
Complete name : C:\Users\Exilit\Desktop\qdqd temp files\qdqd.wav
Format : Wave
File size : 30.8 MiB
Audio
Format : PCM
Codec ID : 1
Bit depth : 16 bits
Stream size : 1.00 Byte (0%)
Audio encoding using BeSweet
"D:\StaxRip\Applications\BeSweet\BeSweet.exe" -core( -input "C:\Users\Exilit\Desktop\qdqd temp files\qdqd.wav" -output "C:\Users\Exilit\Desktop\qdqd temp files\qdqd_Output.m4a" ) -ota( -norm 0.97 ) -bsn( -vbr 0.3 )
[00:00:00:000] Initializing...
[00:00:00:000] -- Initializing...
[00:00:06:120] |*************************************************************
* Nero AAC Encoder *
* Copyright 2009 Nero AG *
* All Rights Reserved Worldwide *
* Package build date: Feb 18 2010 *
* Package version: 1.5.4.0 *
* See -help for a complete list of available parameters. *
[00:00:42:066] |
Start: 22:53:18
End: 22:53:19
Duration: 00:00:00
x264
"D:\StaxRip\Applications\x264\x264.exe" --preset slow --crf 21 --output "C:\Users\Exilit\Desktop\qdqd temp files\qdqd_Output.h264" "C:\Users\Exilit\Desktop\qdqd temp files\qdqd.avs"
avs [info]: 1280x720p 0:0 @ 30/1 fps (cfr)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
x264 [info]: profile High, level 3.1
x264 [info]: frame I:6 Avg QP:19.63 size: 45905
x264 [info]: frame P:432 Avg QP:21.94 size: 23428
x264 [info]: frame B:824 Avg QP:23.47 size: 10431
x264 [info]: consecutive B-frames: 5.9% 9.4% 35.7% 49.1%
x264 [info]: mb I I16..4: 11.0% 73.6% 15.3%
x264 [info]: mb P I16..4: 4.9% 20.3% 3.0% P16..4: 44.0% 13.2% 4.8% 0.0% 0.0% skip: 9.8%
x264 [info]: mb B I16..4: 0.6% 2.7% 0.5% B16..8: 46.7% 8.5% 1.3% direct: 4.8% skip:34.9% L0:47.0% L1:50.4% BI: 2.6%
x264 [info]: 8x8 transform intra:71.5% inter:80.0%
x264 [info]: direct mvs spatial:99.2% temporal:0.8%
x264 [info]: coded y,uvDC,uvAC intra: 66.5% 49.7% 8.1% inter: 24.5% 20.8% 0.1%
x264 [info]: i16 v,h,dc,p: 32% 19% 7% 41%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 9% 7% 7% 10% 15% 14% 14% 11% 13%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 12% 9% 6% 9% 14% 12% 14% 10% 14%
x264 [info]: i8c dc,h,v,p: 31% 34% 23% 12%
x264 [info]: Weighted P-Frames: Y:2.8% UV:1.6%
x264 [info]: ref P L0: 55.9% 14.3% 14.2% 6.9% 6.1% 2.5% 0.0%
x264 [info]: ref B L0: 82.1% 10.5% 5.7% 1.7%
x264 [info]: ref B L1: 94.6% 5.4%
x264 [info]: kb/s:3611.66
encoded 1262 frames, 24.88 fps, 3611.66 kb/s
Start: 22:53:19
End: 22:54:10
Duration: 00:00:51
General
Complete name : C:\Users\Exilit\Desktop\qdqd temp files\qdqd_Output.h264
Format : AVC
File size : 18.1 MiB
Video
Format : AVC
Format profile : High@L3.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Height : 720 pixels
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 119 r2106 07efeb4
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Muxing using MP4Box
"D:\StaxRip\Applications\MP4Box\MP4Box.exe" -fps 30.000 -add "C:\Users\Exilit\Desktop\qdqd temp files\qdqd_Output.h264#video:name=Video" -new "C:\Users\Exilit\Desktop\qdqd.mp4"
AVC-H264 import - frame size 1280 x 720 at 30.000 FPS
Import results: 1262 samples - Slices: 6 I 432 P 824 B - 1 SEI - 6 IDR
Stream uses B-slice references - max frame delay 2
Saving C:\Users\Exilit\Desktop\qdqd.mp4: 0.500 secs Interleaving
Start: 22:54:10
End: 22:54:10
Duration: 00:00:00
General
Complete name : C:\Users\Exilit\Desktop\qdqd.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom
Duration : 42s 67ms
Overall bit rate : 3 615 Kbps
Encoded date : UTC 2012-07-27 20:54:10
Tagged date : UTC 2012-07-27 20:54:10
Video
Format : AVC
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 42s 67ms
Bit rate : 3 612 Kbps
Maximum bit rate : 5 262 Kbps
Height : 720 pixels
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.131
Stream size : 18.1 MiB (100%)
Title : Video
Job Complete
Start: 22:53:18
End: 22:54:10
Duration: 00:00:52
