Seite 4 von 5 ErsteErste ... 2345 LetzteLetzte
Ergebnis 31 bis 40 von 44
Thema: Quicktime AAC Encoder: qaac und qtaacenc
  1. #31
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    Standard AW: Quicktime AAC Encoder: qaac und qtaacenc
    [qaac] release 2.54
    Code:
    Fix: Since 2.52, qaac has been compiled with MSVC14, and couldn't open non WAV files larger than 2GB, because of the C runtime change on MSVC14.
  2. #32
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    [qaac] release 2.55
    Code:
    Yet another UniversalCRT compatibility issue. Since 2.52, qaac couldn't read file formats other than WAV on Windows XP.
  3. #33
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.56
    Code:
    Allow path separators (slash or back slash) in --fname-format, and automatically create directory hierarchy according to the spec given by --fname-format.
    Fixed a typo (--tag:geID tag was ignored because of this).
    Added debugger output.
  4. #34
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.57
    Code:
    New option: --tag-from-file. This option is similar to --tag, but tag value is read from a file. Character encoding is guessed, but you can specify it by --text-codepage.
    New option: --copy-artwork. When specified, front cover art is copied from source file. When --artwork is also specified, this option is ignored. Artwork can be resized by --artwork-size.
    Better support of tags in files referred from a cuesheet. Now they are also imported.
    Disallow decoding FLAC file via libsndfile. If you want FLAC, use libFLAC.
    Ogg Vorbis decoding support via libsndfile.
  5. #35
    Erklär-Bär Avatar von LigH
    Registriert seit
    19. April 2003
    Ort
    OPAL-Invalidengebiet Altmark
    Alter
    43
    Beiträge
    42.755
    [qaac] release 2.58
    • Fixed: mono files couldn't be encoded to AAC since 2.56.
    news | cabinet
    Auf gute Zusammenarbeit:
  6. #36
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.59
    Code:
    Fix: Was failing encoding mono AAC to AAC.
    Support Wavpack v5 interface (with large file support)
    Wavpack version 5 is still in alpha state, and DLL is not officially provided. If you want to try it, you have to build it yourself from the source code.
    This version of qaac supports both of old and new Wavpack DLL (they are binary compatible). When new functions provided in version 5 library are detected, qaac will use them.
  7. #37
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.60
    Code:
    Fix: combination of --adts and --concat was generating invalid AAC file.
    Changed 7.1ch rear channel layout in favor of Apple QuickTime.
    Support new Wavpack v5 64bit API
    Update: libsoxr
    Update: taglib
    qaac was using 3 front + 2 side + 2 back for 7.1ch rear output. However, it turned out that Apple QuickTime cannot handle this, and only recognizes 3 front + 4 back. OTOH, libavcodec couldn't recognize the latter until this patch https://ffmpeg.org/pipermail/ffmpeg-cvslog/2015-June/090556.html. Anyway it now handles both, so I decided to change 7.1ch rear layout to 3 front + 4 back, which is supported by both of them
  8. #38
    Registriert seit
    19. April 2003
    Ort
    Alter
    43
    Beiträge
    42.755
    Für Version 2.60 wird aktuell eine falsche 7.1-Kanalreihenfolge gemeldet.
    [qaac] release 2.61
    Fix 7.1ch PCE: was incorrectly writing object_type(2) instead of profile(1). AFAIK, this doesn't seem to actually affect decoders because decoders are only interested in channel layouts in PCE, but still it was incorrect, and should be fixed.
  9. #39
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.62
    Code:
    Add support on Wavpack-DSD file (requires wavpack v5 DLL).
  10. #40
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    2.63
    Code:
    Support decoding FLAC in MP4.
    AAC decoder: now recognizes 6.1ch/7.1ch AAC channel config constants (11 and 12) defined in 14496-3:2009/Amd 4:2013
    Concatenating files with no title tag with --concat now creates empty chapter name (formerly file name was used).
    --start now accept negative value. using --start and --delay at the same time is not allowed now. These two options are the same in functionality-wise, except for the reversed sign (For trimming, you use positive value for ---start, and negative value for --delay).
    --adts and --concat doesn't allow concatenating files with varying sample format anymore.
    External dlls are now loaded in lazy way, which means that they are not loaded until needed.
    Increased buffering size for --play to avoid glitches on multi channel files.
    --native-resampler now always use dedicated AudioConverter.
    CAF: enabled 7.1ch rear AAC output.
    AAC in CAF: when chan chunk is not present, get channel layout from kuki chunk.
    Named pipe output is removed. I guess it has been rarely used anyway, but if you happen to want it, use https://github.com/nu774/namedpipe .
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Antworten: 0
    Letzter Beitrag: 3. October 2011, 12:46
  2. VFR-Quicktime konvertieren - wie?
    Von aLu im Forum AviSynth
    Antworten: 28
    Letzter Beitrag: 14. May 2007, 22:45
  3. mp4(avc,aac) für Quicktime,...
    Von Selur im Forum Alternative A/V-Container und -Formate
    Antworten: 6
    Letzter Beitrag: 11. September 2006, 09:14
  4. Quicktime Alternative?
    Von DJ-Spacelab im Forum Abspielprobleme
    Antworten: 10
    Letzter Beitrag: 4. November 2005, 20:06
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
