Seite 3 von 16 ErsteErste 1234513 ... LetzteLetzte
Ergebnis 21 bis 30 von 153
Thema: madVR - high quality video renderer (GPU assisted)
  1. #21
    Scheibenwelt-Bewohner Avatar von Tom Keller
    Registriert seit
    6. November 2004
    Beiträge
    677
    Standard AW: madVR - high quality video renderer (GPU assisted)
    Code:
    v0.75
    * fixed: v0.74 stopped decoder DirectShow filter from being released properly
    * fixed: PotPlayer sometimes crashed when switching video files
    * fixed: internal decoders made problems with cropped MKVs & Haali Splitter
    * fixed: OSD sometimes didn't appear in ZoomPlayer in exclusive mode
    * fixed: VP70 decoder showed video upside down
    * fixed: RGB24 input sometimes crashed madVR
    * fixed: ffdshow RGB input level detection sometimes failed
    * subtitles run through the 3dlut now, too
    * internal decoders are now auto disabled if required decoder dlls are missing
    * added option to scale Luma in linear light, disabled by default
    * RGB input with unknown range is now treated by default as full range
    * added detailed information about matrix, primaries and levels to debug OSD
    * updated libav/ffmpeg dlls
    v0.76
    * fixed: crash on MPC-HC exit / close file
    * fixed: OSD didn't show properly or didn't show at all
    * fixed: subtitles showed with a black backgroudn
    * fixed: trade quality -> use 10bit chroma option was used for luma sometimes
    * unfortunately subtitles are not running through 3dlut, anymore
  2. #22
    Erklär-Bär Avatar von LigH
    Registriert seit
    19. April 2003
    Ort
    OPAL-Invalidengebiet Altmark
    Alter
    42
    Beiträge
    42.697
    Seitenwechsel — Immer noch die selbe Download-URL: https://madshi.net/madVR.zip
    Auf gute Zusammenarbeit:
  3. #23
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.77
    * added support for ffmpeg/libav h264 4:2:2 decoding
    * optimized ffmpeg/libav compiling options
    * fixed: madVR disliked getting 2 frames with identical timecodes all the time
    * modified autodetect priorities slightly
  4. #24
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.78
    * added support for DXVA2 deinterlacing
    * added option to enable/disable automatic activation of deinterlacing
    * added option to force off deinterlacing for 48i sources
    * added option enable/disable performing deinterlacing in a separate thread
    * added auto 4:2:2/4:4:4 to 4:2:0 conversion when using DXVA2 deinterlacing
    * added OSD deinterlacing information
    * Ctrl+Alt+Shift+D turns deinterlacing on/off
    * Ctrl+Alt+Shift+F switches deinterlacing field order (auto, top, bottom first)
    * changed gamma decrease key combo from Ctrl+Alt+Shift+F to Ctrl+Alt+Shift+B
    * increased decoder queue size to 12 frames
    * added support for h264 10bit 4:2:2 decoding
    * improved frame stepping
    * improved internal frame locking mechanism
    * removed warning "creating 10bit render texture failed, used 8bit instead"
  5. #25
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.79
    * modified deinterlacing logic to save GPU RAM
    * added resource manager to save GPU RAM and a little bit of GPU performance
    * added information about used / total GPU RAM to debug OSD (Ctrl+J)
    * added new options to choose decoder and GPU queue sizes
    * added automatic adjustment of queue sizes, based on GPU RAM size
    * corrected queue sizes with deinterlacing turned on (size 1 too high in v0.78)
    * improved deinterlacing quality at the start of playback and after seeks
    * improved the way madVR calls DXVA2 (now more similar to EVR)
    * moved some eventually CPU intensive code from render to separate thread
    * optimized performance of DXVA2->PixelShader texture conversion for some GPUs
    * optimized internal libav decoder format conversion logic
    * movie frame rate overwrite via file name now also set deinterlacing on/off
    * option "perform deinterlacing in separate thread" is now "on" by default
    * MPC-HC OSD text "Pausa" is now blocked (to avoid disappearing subtitles)
    * fixed: source cropping (J.River MC) could result in corrupted chroma channel
    * fixed: IMediaSample allocator wasn't fit for decoder queue size of 12 frames
  6. #26
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.80
    * added IVTC algo with decimation and support for 3:2, PAL and Anime cadences
    * Ctrl+Alt+Shift+T switches between video (DXVA) and film (IVTC) content type
    * fixed: moving media player to another monitor made DXVA deinterlacing crash
    * fixed: DXVA deinterlacing produced wrong colors (only with HD videos + ATI)
    * fixed: after a refresh rate change the composition rate didn't update
    * fixed: calculation of consumed GPU RAM was wrong
    * fixed: minimizing ZoomPlayer with playing video made some problems
    * fixed: v0.79 didn't always detect external refresh rate changes
    * fixed: some h264 AVI files made madVR crash, depending on the splitter
    * fixed: improved internal decoder MPEG2 timestamp handling
    * fixed: zooming video extremely small made madVR close the media player
    * fixed: video was positioned wrong when media player cropped top/left
    * fixed: a couple of small Direct3D related bugs
    * fixed: a little resource leak
    * improved presentation timestamp correction a bit
    * improved "IMadVRExclusiveModeInfo::IsExclusiveModeActive"
    * improved "IMadVRExclusiveModeControl::DisableExclusiveMode"
    * added window size checks to detect to-be-expected exlusive mode failures
    * added new interface "IMadVRDirect3D9Manager" for XBMC (work in progress)
    * modified automatic queue sizes
    * improved logging during media player shutdown
  7. #27
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.81
    * added automatic exception catching functionality
    * added manual freeze report functionality (press Ctrl+Alt+Shift+Break)
    * added option to switch display mode only when media player is in fullscreen
    * added option to restore display mode when media player leaves fullscreen
    * display mode changer now reacts on film (24p) vs. video (60p) content type
    * improved renderer behaviour when display mode changes
    * improved ivtc: faster detection of cadence changes
    * improved ivtc: more robust against compression artifacts
    * deint + ivtc is now auto activated for 60i movies which are tagged to 24 Hz
    * ivtc is now auto activated for 50i movies which are tagged to 25 or 24 Hz
    * deinterlacing is only turned on for 50i and 60i movies now
    * added patch to MS VC-1 decoder -> deinterlacing off
    * modified file name tagging logic (24p, 24i, 24fps, 24Hz, etc)
    * improved behaviour with decoders which don't output proper interlaced flags
    * improved exclusive -> windowed mode behaviour slightly, mainly for ZoomPlayer
    * added "sharpness: 100" option for Bicubic scaling
    * queue sizes are now always 16/8 by default, no more automatic adjustments
    * keyboard shortcuts: always only change things temporarily by default now
    * keyboard shortcuts: some changes (not all) can be stored by pressing F2 now
    * the source levels (TV vs PC) can be stored now
    * the source content type (film vs video) can be stored now
    * key presses are now only "swallowed" if media player process has key focus
    * osd keyboard handling runs in its own thread now
    * added many more languages to the "Pause" MPC-HC message block
    * used GPU RAM is now shown in osd, anymore
    * increased upload thread priority slightly
    * fixed: ZoomPlayer eventually froze when leaving exclusive mode
    * fixed: some users had composition rate in exclusive mode OSD -> problems
    * fixed: crash when video window size was reduced to a very small size
    * fixed: frame stepping sometimes resulted in weird play/pause mixed state
    * fixed: one case where "delay playback start..." resulted in paused state
    * fixed: v210 pitch/stride handling was broken
    * fixed: YV24 had swapped chroma channels
    * fixed: YV24 DXVA deinterlacing resulted in image corruption
    * fixed: OSD API didn't capture mouse events on mouse down
  8. #28
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.82
    * added: new option to activate deinterlacing if in doubt whether it's needed
    * added: new IVTC option to only look at pixels in the frame center
    * added: IVTC "cadence breaks" information to OSD; resets with Ctrl+R, as usual
    * deinterlacing + IVTC are now always forced on for 60i sources tagged as 24Hz
    * improved IVTC cadence logic
    * improved DXVA deinterlacing behaviour slightly
    * improved display mode change event handling
    * improved exclusive -> windowed switch a little bit more
    * fixed: madVR sometimes didn't notice changed display mode
    * fixed: if DXVA2 deinterlacing was not available in XP, it made madVR crash
    * fixed: crash when moving madVR to another display with ZoomPlayer
    * fixed: freeze when switching subtitles in paused state
    * fixed: closing down madVR didn't always wait for the closing to complete
    * fixed: closing the media player while madVR was in exclusive mode -> freeze
    * fixed: sometimes asking for a freeze report created multiple reports at once
    * fixed: MS DVD Navigator caused error in the primaries/matrix auto detection
    * fixed: when switching from Bicubic to SoftCubic, options weren't updated
    * fixed: red error messages were supposed to disappear after a while but didn't
    * fixed: red error messages no longer show duplicate error messages
    v0.82.1
    * fixed: playback is sometimes stuck with a black screen (introduced in v0.82)
    * fixed: seeking sometimes results in frozen video frame (introduced in v0.82)
    v0.82.2
    * fixed: SoftCubic was stuck on "softness: 50" (introduced in v0.82)
    * fixed: in certain situations there was a new freeze (introduced in v0.82)
    * fixed: PotPlayer crashed sometimes when turning audio processing on/off
    * fixed: option "if in doubt activate deinterlacing" didn't work properly
    v0.82.3
    * fixed: Ctrl+C / File Close didn't work in MPC-HC  (introduced in v0.82)
    * fixed: Ctrl+E in MPC-HC didn't work  (introduced in v0.82)
    * fixed: finalization crash due to stupid bug  (introduced in v0.82)
    v0.82.4
    * fixed: 2 more finalization crashes
    * fixed: display mode changer stopped working after a 2nd video file was loaded
    * fixed: filter properties dialog didn't show the full madVR version number
    Geändert von Tom Keller (7. March 2012 um 22:23 Uhr)
  9. #29
    Kaiser
    Registriert seit
    6. July 2009
    Beiträge
    1.329
    Code:
    madVR v0.82.5 released
    Code:
    * improved D3D11 exclusive -> windowed switch slightly, still not great, though
    * option "delay playback start..." now requires both GPU+CPU queues to be full
    * fixed: YCgCo decoding matrix was not correct
    * fixed: internal 4:4:4 decoding produced wrong colors (introduced in v0.81)
    * fixed: display mode changer didn't always activate when entering fullscreen
    * fixed: forcing deinterlacing + IVTC on was caused by 30p tag instead of 24p
    * fixed: h264 media type parsing sometimes crashed
    * fixed: crash when no filter in the chain provided frame rate information
    * fixed: one thread was started per video frame (introduced in v0.82)
    * maybe fixed: entering/leaving exclusive mode steals keyboard focus
    Ab jetzt wird es vermehrt diese "Unternumerierung" der Versionsnummer geben, da madshi sonst zu schnell bei "1.0" wäre.
  10. #30
    Registriert seit
    19. April 2003
    Ort
    Alter
    42
    Beiträge
    42.697
    Bloß nie "fertig" werden!
    Zu Archivierungszwecken wäre es wohl nett, wenn die ZIP-Datei auch mal Versionsnummern im Namen hätte, nicht immer nur die selbe Datei überschreiben:
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Haalis Video Renderer - Starkes Blocking
    Von Bumsfalara im Forum Abspielprobleme
    Antworten: 27
    Letzter Beitrag: 28. February 2008, 22:07
  2. High Quality - Deinterlacing mit AVISynth
    Von scharfis_brain im Forum AviSynth
    Antworten: 109
    Letzter Beitrag: 3. March 2007, 14:20
  3. Video Renderer im Zoomplayer
    Von aba9291281 im Forum Abspielprobleme
    Antworten: 0
    Letzter Beitrag: 5. May 2006, 01:38
  4. PAL-60 high quality capture
    Von der-doktor im Forum Analoges Video-Capturing
    Antworten: 4
    Letzter Beitrag: 1. February 2004, 14:10
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
