Seite 2 von 16 ErsteErste 123412 ... LetzteLetzte
Ergebnis 11 bis 20 von 153
Thema: madVR - high quality video renderer (GPU assisted)
  1. #11
    Scheibenwelt-Bewohner Avatar von Tom Keller
    Registriert seit
    6. November 2004
    Beiträge
    677
    Standard AW: madVR - high quality video renderer (GPU assisted)
    Code:
    v0.43
    * restored some v0.36 behaviour for exclusive -> windowed switch (XP only)
    * fixed FLV problem (introduced with v0.42)
    * fixed bug which resulted in Aero en/disabling happening incorrectly
    v0.42
    * changed aspect ratio reporting back (PotPlayer and JR MC didn't like v0.41)
    * improved forced redrawing of all GUI stuff after exclusive -> windowed switch
    * removed some of the "disable desktop composition" modes
    v0.41
    * added workaround for buggy decoders (hopefully it breaks nothing else)
    * added forced redrawing of all GUI stuff after exclusive -> windowed switch
    v0.40
    * turning desktop composition back on should be without delay now
    * DXVA NV12 connections are refused now
    v0.39
    * fixed: 16:9 DVDs were shown as 4:3 (introduced in v0.37)
    v0.38
    * changed mouse cursor management (for J.River MC)
    * added support for NV12 (4:2:0 8bit), P010 (4:2:0 10bit), P016 (4:2:0 16bit)
    v0.37
    * IBasicVideo::SetDestinationPosition not needed, anymore (for J.River MC)
    * exclusive -> windowed switch should be a bit faster in Vista+ now
    * added options for disabling desktop composition
    * added workaround for MPC-HC MPEG2 decoder crash with VOB files (decoder bug)
    * settings dialog now remembers the page you've been on
    * fixed small bug in video levels output math
    v0.36
    * fixed: settings changes only showed affect after reloading the video
    * fixed: Ctrl+Y didn't work properly, anymore
    * hopefully fixed: madVR startup delay on some PCs
    v0.35
    * reverted back to v0.32 clock logic (no more clock jitter removal)
    * fixed: ESC (= pause + minimize) in KMPlayer in exclusive mode -> freeze
    * fixed: multi monitor device management didn't fully work
    * maybe fixed: problem with ZP + MKV splitter + exclusive mode + playlist
    * added logging to gather more info about one instance of madVR freezing
    v0.34
    * fixed: resizing media player window made problems (introduced with v0.33)
    v0.33
    * fixed: crash when source filter didn't allocate chapter names
    * added algorithm to remove audio clock jitter
    * added country flags for video/audio/subtitle tracks in tray icon menu
    * moved "close media player" above audio/subtitle tracks in tray icon menu
    * modified clock deviation measurement algorithm
    * added "ideal refresh rate" information to OSD
    * added madVR version number to debug log output
    * "video size changed" event is sent more selectively, now
    v0.32
    * fixed: calculation of estimated frame drops/repeats was incorrect
    * fixed: one madVR shutdown crash cause
    * fixed: log file was held locked even after madVR finalization
    * simplified tray icon menu structure (less submenus)
    * left and right click on tray icon shows different context menus now
    * added monitor/receiver device management functionality to settings logic
    * monitor/receiver devices are now automatically detected and identified
    * monitor related settings are now stored separately per monitor device
    * ffdshow is not asked for audio/subtitle streams, anymore (stability issues)
    v0.31
    * fixed: sometimes frames were incorrectly dropped in paused state
    * fixed: SoftCubic100 didn't stick for Luma up/downscaling
    * fixed: media player icon was not transfered correctly from win7 to XP
    * local communication is not done via TCP/IP, anymore -> no firewall problems
    * the exe/dll/ax files are now signed to reduce anti virus false alarms
    * added reference vs. system "clock deviation" information to OSD
    * added information about estimated number of dropped/frames per second to OSD
    * uninstall.bat now automatically removes the tray icon
    * added new option "delay switch to exclusive mode for 3 seconds"
    * renamed some settings folders
    v0.30
    * fixed: some scaling options didn't "stick"
    * added workaround for stack overflow with some videos (not madVR's fault!)
    * madVR settings dialog is now "always on top"
    * tray icon configuration dialog is now "always on top"
    v0.29
    * fixed: crash when trying to enter the 3dlut settings tab
    * fixed: settings dialog didn't work when tray icon was disabled
    * fixed: tray icon didn't properly go away in certain circumstances
    v0.28
    * fixed: seek bar was sometimes shown even with exclusive mode disabled
    * fixed: logging could result in frame drops
    * fixed: new frame drop logic (v0.27) sometimes dropped more than necessary
    * fixed: sometimes madVR started with a black screen and then crashed
    * maybe fixed: exclusive mode didn't work with interlaced refresh rates
    * full rewrite of settings logic
    * first draft of completely new settings dialog
    * added "mad* home cinema control" tray icon
    * added tray icon configuration dialog
    * added media player controls (play, pause, stop, exit) to tray icon
    * added video/audio/subtitle switching functionality to tray icon
    * added chapter selection functionality to tray icon
    * added seek intervals to tray icon
    * added automatic listing of media players running madVR on any PC in the LAN
    * added LAN media player remote control abilities to tray icon
    * sysinternals ProcessExplorer is not "overpowered", anymore
    * removed timing model tweak option
    v0.27
    * fixed: after switch to windowed mode seek bar sometimes stayed active forever
    * fixed: sometimes after a Direct3D reset, rendering stopped working
    * exclusive mode does now "overpower" all other processes, except task manager
    * frame drop/delay logic fully rewritten
    * when switch to exclusive mode fails, madVR now goes back to windowed mode
    * madVR seek bar is now also shown in fullscreen windowed mode
    * added forced OSD display "PC/TV levels" when using Ctrl+Alt+Shift+Y
    * modified dynamic media type change handling a bit to reduce overhead
    v0.26
    * fixed: windows on primary monitor were seen as covering secondary playback
    * fixed: when starting in fullscreen mode, madVR's seek bar didn't work
    * fixed: starting ZoomPlayer in fullscreen exclusive mode made problems
    * when "maximizing" the media player, exclusive mode is activated at once now
    * exclusive mode switch is now done after 3 seconds instead of 1 second
    * while exclusive mode is active, media player window is made topmost now
    * windowed tweak "timing model" is now used for exclusive mode, too
    * changed Aero timing mode once again
    * added forced OSD display "windowed" vs. "exclusive" when switching
    * new interface allows media players to ask whether madVR is in exclusive mode
  2. #12
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.46
    * reverted change introduced in v0.43 which might have caused instability
    * modified subtitle syncing logic
    * ISubRenderCallback is now only used for MPC-HC builds >= 1.5.2.2988
    v0.45
    * fixed: video rectangle was sent incorrectly to subtitle renderer
    v0.44
    * fixed ZoomPlayer OSD graphical corruption problem (again)
    * fixed bug in OSD text message handling
    * added support for subtitle rendering through ISubRenderCallback
    Geändert von Tom Keller (21. March 2011 um 07:38 Uhr)
  3. #13
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.53
    * moving madVR to another monitor during playback is now properly handled
    * a couple more tweaks to the new exclusive mode rendering path
    * vsync handling now uses its own Direct3D device instance
    * improved handling of rendering failures
    * OSD: rendering/presentation stats are now only shown when they're meaningful
    * OSD: queue and dropped frames information is now directly next to each other
    v0.52
    * fixed: presentation glitches were not reported at all
    * fixed: reaction to presentation glitches was (very) wrong
    * added some more fixes and tweaks to the new exclusive mode rendering path
    * fixed: seek bar sometimes got stuck with new exclusive path when paused
    * fixed: starting in paused mode sometimes failed to show first video frame
    * fixed: pre-render option wasn't always enabled/disabled correctly
    * debug OSD is now green instead of red (doom9 majority wish)
    v0.51
    * fixed: seeking while paused with new exclusive path didn't update image
    * added D3D9 tweak to allow pre-rendering of more than 3 frames
    * added a number of fixes and tweaks to new exclusive mode rendering path
    * readded "presentation glitches" to OSD, but only for new exclusive path
    * added option to choose the no of pre-rendered frames for new exclusive path
    v0.50
    * added new exclusive mode rendering path
    * added option to use the old exclusive mode rendering path
    * fixed: settings window suddenly showed in taskbar, wasn't supposed to
    * changed "disable desktop composition" default setting to "off"
    * removed option "upload frames in render thread", forced to "off" now
    * removed "presentation glitches" information from OSD (was always 0, anyway)
    * madHcNet doesn't initialize WinSock, anymore, when LAN access is disabled
    v0.49
    * fixed: settings could not be edited if a monitor had a unicode name
    * fixed: settings dialog with tray icon disabled took a long time to appear
    * fixed: sometimes "madVR instance didn't reply properly" appeared
    * settings are now stored under "HKCU\Software\madshi\madVR\Settings", too
    * LAN support is disabled by default now, can be enabled through tray icon menu
    v0.48
    * fixed: resource leak in OSD text messages
    * disabled "Play" and "Pause" OSD messages until rendering chain is rewritten
    * added support for ISubRenderCallback2, appears to fix subtitle sync problems
    v0.47
    * fixed: madVR didn't close properly
    Geändert von Tom Keller (14. April 2011 um 20:37 Uhr)
  4. #14
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.58
    * fixed: 23p/59i movie did not activate 59p display mode
    * removed v0.57 win7 specific presentation path again, didn't work so well
    * added glitch hack as a new render option (Vista/Win7 only)
    v0.57
    * added (simple) automatic display mode changer
    * added slightly modified exclusive presentation path for win7 and newer OSs
    * if decoder doesn't tell the source framerate, madVR searches upstream
    * if DScaler IVTC Mod is in the graph, madVR considers 29.970 to be 23.976
    * if source file name contains framerate token, that overwrites DirectShow info
    * added hack to stop Direct3D from messing up refresh rates
    * added batch file to restore default settings
    * fixed: in XP setting the number of pre-presented frames to 1 didn't work
    * fixed: secondary display attached to a receiver wasn't handled correctly
    v0.56
    * fixed: going directly to fullscreen mode made madVR freeze
    v0.55
    * a couple of bugfixes and improvements for dual monitor setups
    * added new render option tab named "exclusive mode settings"
    * moved some exclusive mode options from "general settings" tab to new tab
    * added separate flush options for exclusive mode (old and new path)
    v0.54
    * fixed high CPU consumption in new exclusive mode rendering path (hopefully)
    * added option to use windowed mode flush tweaks for new exclusive path, too
    * added batch file to switch between debug <-> release mode
    Geändert von Tom Keller (20. April 2011 um 01:49 Uhr)
  5. #15
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.61
    * fixed: exclusive -> windowed with D3D11 made media player buttons disappear
    * fixed: exclusive -> windowed with D3D11 made media player window too big
    * fixed: closing video file in D3D11 exclusive mode resulted in crash
    * added new tweak option "overshoot max frame latency"
    v0.60
    * fixed: fullscreen exclusive mode was sometimes not activated properly
    * Windows Key press now forces a 3 second delay before going back to exclusive
    v0.59
    * added D3D11 presentation path
    * renamed glitch hack to "use a separate device for presentation"
    * added option to activate D3D11 presentation path
    * switched and renamed option "present only one frame at a time"
    * added tweak option "run presentation in a separate thread"
    * added tweak option "limit rendering times to avoid glitches"
    * added option "restore original display mode when media player closes"
    * added option "treat 25p movies as 24p (requires Reclock)"
    * added detection for "Windows Key" press -> switch out of exclusive mode
    * fixed: having only one mode in the display mode switcher didn't work
    * fixed: when entering fullscreen, sometimes the seekbar incorrectly showed up
    * fixed: changing refresh rate behind madVR's back resulted in a freeze
    * fixed: ZoomPlayer froze when moving to secondary monitor fullscreen playback
    * a couple more minor changes and bugfixes
    Geändert von Tom Keller (28. April 2011 um 19:29 Uhr)
  6. #16
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.65
    * fixed: decode matrix + source primaries detection only worked once
    * fixed: yet another bug in the automatic display changer
    v0.64
    * changed a couple of calibration related texts
    * Ctrl+Alt+Shift+C toggles gamma curve type now instead of Ctrl+Alt+Shift+T
    * Ctrl+Alt+Shift+M toggles decoding matrix
    * Ctrl+Alt+Shift+P toggles source primaries
    * fixed: disabling gamma processing didn't show immediate effect
    * fixed: one more display mode changer bug
    * added support for switch to 59i/60i display mode for 59p/60p content
    * Windows key now only stops exclusive mode when running on primary monitor
    * seekbar is now shown only if mouse cursor is on playback monitor
    * when the PC is locked (Windows Key + L) madVR now pauses playback
    * fixed: D3D11 playback on secondary monitor could result in window size bug
    v0.63
    * fixed: couple of bugs in the display mode changer
    * fixed: nearest neighbor in v0.62 was broken (bilinear was used instead)
    * fixed: removed nonsense 9bit/10bit display bitdepth options
    * fixed: yCMS tab in settings dialog is now only visible on calibration page
    * added: complaint when yCMS is selected, but no gamut measurements provided
    * added new "enable gamma processing" option (default = off)
    * renamed "something else" to "unknown"
    * moved gamut/gamma options from "properties" page to "calibration" page
    * gamut/gamma options in calibration page are now grayed out when using 3dlut
    * gamma processing can't be enabled if calibration -> gamma is set to "unknown"
    * added primary/gamut "sRGB" option
    v0.62
    * added display "properties", "calibration" and "color & gamma" settings pages
    * added option to define the native display bitdepth (affects dither strength)
    * added options to define how the display was calibrated (gamut + gamma)
    * moved "Video/PC levels" option to display "properties" settings page
    * added options to define which gamma / transfer function to use
    * replaced old "use 3dlut" option with new controls on "calibration" page
    * added integrated GUI for yCMS 3dlut creation, no more console hacking needed
    * added "please wait" dialog while yCMS is downloaded + installed
    * added "please wait" dialog while 3dlut file is created
    * added support for 6 and 7 bit 3dlut files (see trade quality for performance)
    * added option to choose a manually created external 3dlut file (per display)
    * there's only one 3dlut file per display now
    * 3dlut is now always yRGB / RGB_Video input and RGB_Video output
    * YCbCr -> RGB conversion is now always done by shader math, not by 3dlut
    * Video/PC levels conversion is now always done by shader math, not by 3dlut
    * rewritten rendering and pixel shader chain
    * subsampled YCbCr is now upsampled & converted to RGB first, then scaled
    * chroma upsampling got quite a bit faster (because it's now always exactly 2x)
    * luma scaling got a tiny bit faster, depending on scaling factor and taps
    * Strg+Alt+Shift+C displays & toggles color format (BT.709 -> BT.601 -> PAL)
    * Strg+Alt+Shift+G displays and increases the Gamma value (2.20 -> 2.25 -> ...)
    * Strg+Alt+Shift+F displays and decreases the Gamma value (2.20 -> 2.15 -> ...)
    * Strg+Alt+Shift+T displays and changes the Gamma curve type (pure power / BT)
    * dither is using a texture again instead of shader math
    * dither is now colored and differs for every video frame
    * added support for  8 bit 4:2:0 media types IYUV, I420, NV21, ICM*
    * added support for  8 bit 4:2:2 media types YUY2, YVYU, UYVY, YV16, yuv2, ...
    * added support for  8 bit 4:4:4 media types AYUV, YV24, I444, v308, v408
    * added support for  8 bit RGB   media types RGB32, RGB24, BGRA, ABGR, RGBA
    * added support for 10 bit 4:2:2 media types P210, Y210, v210
    * added support for 10 bit 4:4:4 media types Y410, v410
    * added support for 16 bit 4:2:2 media types P216, Y216, v216
    * added support for 16 bit 4:4:4 media types Y416, v416
    * added support for 16 bit RGB   media types RGB48, RGB64, b48r, b64a, ...
    * added hints to "install.bat" and "readme.txt" to not delete the madVR folder
    * fixed: madVR rendering window in GraphEdit didn't have correct size
    * changed VSync priority back to "time critical"
    * slightly changed tray icon mouse click behaviour
    Geändert von Tom Keller (8. June 2011 um 04:37 Uhr)
  7. #17
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.66
    * rewritten large parts of the OSD logic
    * added APIs for media player devs to draw their OSDs/GUIs in exclusive mode
    * added API for media player devs to disable the madVR seekbar
    * fixed: OSD is now above subtitles instead of under
    * OSD + seekbar are now drawn to full window size, not to video rect, anymore
    * madVR debug OSD is now white with a dark background
    * using higher internal precision for internal calculations now
    * fixed a couple of bug in gamma / gamut / 3dlut processing
    * instead of yRGB, madVR/yCMS are now using the measured display primaries
    * improved compatability with uncompressed video files
    * fixed: avisynth -> ffdshow -> RGB -> madVR produced upside down image
    * fixed: seekbar showed up when playback monitor was positioned "under" primary
    * simplified calibration settings a bit more
  8. #18
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.69
    * fixed: (again) timestamp for libav/ffmpeg decoders
    * another seeking improvement
    v0.68
    * added support for all primaries referenced by h264, VC-1, MPEG2 and MS
    * added support for all decoding matrices referenced by h264, VC-1, MPEG2 & MS
    * primaries, matrix and range are now read from VC-1, MPEG2 and h264 headers
    * ffdshow RGB output levels are now automatically detected and handled properly
    * added support for primary, matrix and range info via DirectShow media type
    * improved primary and matrix guesses, if no detailed information is available
    * primaries, matrix and range are auto set to what the source requires
    * VC-1, MPEG2, h264 headers are read from external decoders, without their help
    * Ctrl+Alt+Shift+I toggles input levels (source = full range or not)
    * added info to OSD about video bitstream and madVR raw video input formats
    * improved internal decoder seeking behaviour
    * video bitstream AR is used now if no container AR is available
    * libav decoder is now automatically used if Intel decoder can't handle a file
    * Intel decoder is now automatically used for interlaced VC-1 content
    * fixed: some new problems with external decoders, introduced in v0.67
    * fixed: crashes with Intel decoder during playback or when seeking
    * fixed: libav/ffmpeg decoder crashed with full_range h264 videos
    * fixed: bad timestamps with internal libav/ffmpeg decoder
    * fixed: libav/ffmpeg VC-1 decoder showed corruption at the bottom of the image
    * fixed: graphical corruption with internal decoders in certain situations
    * fixed: connection to 4:2:2 h264 streams is now declined
    v0.67
    * added libav/ffmpeg Software Decoders for MPEG2, VC-1 and h264 (experimental)
    * added Intel        Software Decoders for MPEG2, VC-1 and h264 (experimental)
    * added new option "delay playback start until render queue is full"
    * added new interface IMadVRRefreshRateInfo for media player developers
    * fixed: OSD was updated all the time, even in paused state
    * fixed: when using GraphEdit, madVR video window was sometimes too small
    * fixed: madVR asked upstream filter to change output FourCC without need
    Geändert von Tom Keller (25. July 2011 um 01:48 Uhr)
  9. #19
    DAS_CHAOS Avatar von Scratty
    Registriert seit
    28. April 2005
    Beiträge
    75
    Code:
    madVR v0.70
    * delay times improved for option "pause playback until render queue is full"
    * option "pause playback until render queue is full" is now disabled by default
    * exclusive mode tweak options regrouped and branded as "not recommended"
    * internal MPEG2/h264 decoders are enabled by default now, VC-1 stays disabled
    * display mode switcher now "likes" 24.000 Hz mode for 23.976 fps movies better
    * improved timestamps of internal libav/ffmpeg MPEG2 decoder
    * improved seeking with internal libav/ffmpeg h264 decoder
    * fixed: moving from one monitor to another sometimes caused graph to pause
    * fixed: display mode changer caused internal decoders to stop working
    * fixed: gamma processing with RGB input produced a black screen
    * fixed: h264 mediatype parsing corrupted RAM, eventually resulting in a crash
    * fixed: color processing accurateness problems introduced in v0.68
    * fixed: exclusive mode seekbar didn't work during DVD playback
    * fixed: tracks with a "|" in the name confused the tray icon context menu
    * fixed: at playback start, and after unpausing there was sometimes judder
    * fixed: OSD sometimes flickered at playback start, and after unpausing
    Geändert von Scratty (26. July 2011 um 08:57 Uhr)
    OPERATIVE HEKTIK,ERSETZT GEISTIGE WINDSTILLE
  10. #20
    Registriert seit
    6. November 2004
    Beiträge
    677
    Code:
    v0.71
    * for DVD playback start, "delay playback start..." option is now auto disabled
    * when OSD changes, render queue is cut down to 3/8 to make OSD more responsive
    * when madVR pauses/starts/stops graph, notification message 0xFA17 is sent now
    * fixed: crash with NVidia PureVideo MPEG2 Decoder
    * fixed: crash with h264 AVI content
    * fixed: unpause delay with internal decoders in exclusive mode
    * fixed: subtitles disappeared when pausing playback
    * fixed: madVR caused "File Source Async" to never be destroyed
    * fixed: full range YCbCr input showed a green tint (introduced with v0.70)
    v0.72
    * empty file "force full range input" in madVR folder overwrites auto detection
    * empty file "YCbCr" in madVR folder makes madVR output YCbCr data directly
    * fixed: video playback in PotPlayer froze in various situations
    * fixed: display mode change + "delay playback start..." -> video stayed paused
    v0.73
    * fixed (again): video playback in PotPlayer froze in various situations
    * fixed: OSD changes could result in dropped frames (reverted to older code)
    * fixed: crash if the source filter reported a NULL file name
    v0.74
    * fixed: internal decoder showed 10bit video with non-mod-4 width distorted
    * fixed: primaries/matrix auto detection eventually failed if ffdshow upscaled
    * fixed: MPEG2 internal decoder timestamps didn't work well with DVDs/VOBs
    * fixed: ZoomPlayer "Media: Next Track" -> OSD "windowed" stayed forever
    * fixed: corruption with ordered chapters, when using internal decoders
    * added new interface "IMadVRExclusiveModeControl"
    * added new interface "IMadVRSettings"
    * added support for h264 files with a 3-byte NAL length
    Geändert von Tom Keller (22. August 2011 um 20:29 Uhr)
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Haalis Video Renderer - Starkes Blocking
    Von Bumsfalara im Forum Abspielprobleme
    Antworten: 27
    Letzter Beitrag: 28. February 2008, 22:07
  2. High Quality - Deinterlacing mit AVISynth
    Von scharfis_brain im Forum AviSynth
    Antworten: 109
    Letzter Beitrag: 3. March 2007, 14:20
  3. Video Renderer im Zoomplayer
    Von aba9291281 im Forum Abspielprobleme
    Antworten: 0
    Letzter Beitrag: 5. May 2006, 01:38
  4. PAL-60 high quality capture
    Von der-doktor im Forum Analoges Video-Capturing
    Antworten: 4
    Letzter Beitrag: 1. February 2004, 14:10
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
