Seite 14 von 16 ErsteErste ... 41213141516 LetzteLetzte
Ergebnis 131 bis 140 von 156
Thema: madVR - high quality video renderer (GPU assisted)
  1. #131
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    Standard AW: madVR - high quality video renderer (GPU assisted)
    0.91.1
    Code:
    * added NGU "low" quality algorithm
    * "soften edges" and "add grain" now allow smaller adjustment steps
    * fixed: install batch didn't work
    * fixed: on some PCs NGU didn't activate
    * fixed: on some PCs keyboard shortcuts didn't work
    * fixed: NGU grain was static
    * "ShowRenderSteps" hack no longer slows down NGU as much as before
    * "ShowRenderSteps" hack only slows down stuff as long as the OSD is visible
  2. #132
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.2
    Code:
    * renamed NGU quality levels: Low -> Med, Med -> High, High -> VeryHigh
    * added a new even faster NGU "Low" variant
    * reworked chroma/image up/downscaling/doubling settings pages
    * removed NEDI and super-xbr image doubling algorithms
    * small speed improvement for NGU-Med (former NGU-Low)
    * small quality improvement for NGU-Med/High (former NGU-Low/Med)
    * settings dialog warns when SuperRes and NGU are enabled at the same time
    * pixel shader database is compressed now to save space
  3. #133
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.3
    Code:
    * fixed: NNEDI3 doubling could crash in certain situations
    * fixed: NGU chroma upscaling didn't allow "veryHigh"
    * fixed: SuperRes strength controls were disabled for chroma upscaling
  4. #134
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.4
    Code:
    * redesigned "image upscaling" settings page once more
    * super-xbr image doubling is available again
    * fixed: downscaling anti-ringing checkbox was sometimes disabled
  5. #135
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.5
    Code:
    * added direct 4x NGU upscalers
  6. #136
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.6
    Code:
    * added NGU Anti-Alias algorithm, intended as a potential NNEDI3 replacement
    * completely redesigned image upscaling settings page once more
    * downscaling after doubling now uses relaxed AR (instead of strict)
    * increased AdaptiveSharpen + LumaSharpen upper limits
    * fixed: up & downscaling anti-ringing checkbox was sometimes disabled
    * fixed: 3D subtitle depth was incorrect for movies with swapped eyes
  7. #137
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.7
    Code:
    * fixed: doubling twice with "normal" chroma quality resulted in weird colors
    * fixed: "downscaling after doubling" dropbox was missing an item
  8. #138
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.8
    Code:
    * NGU Sharp now targets middle ground between gamma and linear light
    * added NGU Standard + Soft algorithms, with direct quadrupling support
    * added true "very high" quality mode for direct quadrupling
    * modified "add grain" to produce similar output when using direct quad
    * fixed: Y416 input was handled incorrectly
  9. #139
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.9
    Code:
    * added support for sending HDR metadata via Nvidia's private API
    * added support for sending HDR metadata via win10 (not tested yet)
    * fixed: processing (not converting) HDR was not handling gamut correctly
  10. #140
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.232
    0.91.10
    Code:
    * improved Windows 10 HDR metadata support
    * added new option "hack Direct3D to make 24.000Hz and 60.000Hz work"
    * performance improvement with "trust DXVA" + "use D3D11 for presentation"
    * fixed: Intel GPU driver flickering bug with "use D3D11 for presentation"
    * fixed: madVR(64).ax files were larger than necessary
    * Intel: 10bit DXVA surfaces are now converted to 10bit RGB (instead of 8bit)
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. Haalis Video Renderer - Starkes Blocking
    Von Bumsfalara im Forum Abspielprobleme
    Antworten: 27
    Letzter Beitrag: 28. February 2008, 22:07
  2. High Quality - Deinterlacing mit AVISynth
    Von scharfis_brain im Forum AviSynth
    Antworten: 109
    Letzter Beitrag: 3. March 2007, 14:20
  3. Video Renderer im Zoomplayer
    Von aba9291281 im Forum Abspielprobleme
    Antworten: 0
    Letzter Beitrag: 5. May 2006, 01:38
  4. PAL-60 high quality capture
    Von der-doktor im Forum Analoges Video-Capturing
    Antworten: 4
    Letzter Beitrag: 1. February 2004, 14:10
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
