Seite 24 von 25 ErsteErste ... 1422232425 LetzteLetzte
Ergebnis 231 bis 240 von 241
Thema: Avidemux - aktuelle Versionen
  1. #231
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    Standard AW: Avidemux - aktuelle Versionen
    2.6.11
    Code:
    [installer] update whats new
    [2.6.11] Release
    [UI] Make refresh cap a tunable
    [UI] Use delayed refresh
    [year] we are in 2016 now
    [mkv/demux] silence
    [editor] Dont fail completely when there is a decoding error or a bad timestamp
    [Gui] Change the behaviour of slider
    [fade] very basic fade
    [FadeToBlack] fix pitch and display
    [Demux/pics] Manage error loading image more gracefully
    [Core] Support for greyscale
    [jpeg] Better compatibility with large headers
    [mkv] Use time rather than position to map keyframes from cue
    [editor] Fix pivot search when looking for the previous kf
    [Editor/copy] drop frame is DTS is <0
    [ASF] Use duration of video, pretty ugly workaround
    [demux/mp4] basic support for h265
    [mkv/muxer] support opus
    [installer/nsi] Try to do uninstall cleanly
    https://avidemux.sourceforge.net/download.html
  2. #232
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.12
    Code:
    More bugfixes
    *[H264] Fixed crash when saving h264 annexB in avi (Brundle)
    *[Vdpau] Fixed VDPAU resize and deinterlace when height is padded
    *[Mkv] Faster loading of VP9 and h265
    *[MP4] Supports more flavors of H265
    *[i18n] Spanish translation update by ringmaster
    *[Edit] Another frame seeking bug fixed, happened rarely
    *[All] Slightly better crash handler
    *[FFmpeg]Update to 2.7.6
    *[Muxer] Basic webm support
    *[Jobs] Fixed right click menus with qt5
  3. #233
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.13
    Code:
    [build] Release
    [x265] revert non patch
    [x265/Qt] Add none preset (eumagga0x2a)
    [editor] When appending a video, dont reconstruct thus reset the audio pool
    [Qt/UI] Bigger window patch (eumagga0x2a)
    [Build] Try to fix the versioning for good
    [decoder] workaround bad management of switch from sw decoder to hw decoder, it worked by miracle before on vdpau
    [cosmetic]
    [plugin] remove avsfilter for the moment, ppwrite is missing
    [avsWrite] constify
    [coder/decoder] Fix double free when using libva
    [appImage] Add intel driver (untested) + fix command lines
    [appImage] Recompile libva + nvidia-va with a more recent version, intel still missing
    [appImage] Tweaks
    [appImage] more fixes
    [core] More cleanup
    [appImage] also add xcb-dri2
    [core] split platform dependant stuff
    [Qt/osx] Let avidemux manage the preference menu
    [build/osx] Fix --rebuild on osx
    [appImage] Use fusion as default theme, less problem
    [AppImage] Support also translations
    [i18n] Fixup some translation (eumagga0x2a)
    [appImage] Add xcb libs
    [main] Proper scriptEngine folder in appImage mode
    [appImage] better (?) command line support
    [build] Update El Capitan build script
    [core/mac] simplify
    [app] Remove cruft
    [core] constify win32 version
    [build] more getRevision tweaks
    [i18n] german update (eumagga0x2a)
    [i18n] Make more strings translatable (eumagga0x2a)
    [appImage] Tweak build scripts
    [appImage] add x264 and x265
    [core] Tweak install dir folder
    [appImage] tune scripts
    [appImage] more support libs
    [build/appImage] more support libs
    [build/Qt5] tweak include dirs
    [appImage] audio deps
    [appImage] skeleton
    [build] getRevision, try also parent folder
    [build] AppImage
    [cosmetic] set proper name for hflip (eumagga0x2a)
    [filter] Cosmetic rename filter (sl1pkn07)
    [editor] Fix signed vs unsigned arithmetic, caused problem when copy saving some TS vids
    [i18n] Sort language + remove bad russian i18n entry (eumagga0x2a)
    [i18n] Add more language (eumagga0x2a)
    [avs] fix path
    [AvsFilter] Fix binary install
    [plugin/script] Temporary fix for scripts needing Editor interface
    [i18n] Dk translation by scootergrisen
    [Build] Forgotten files
    [build] More or less complete change
    [build] Add audioCodec
    [Build] Disable engine, fix other plugins. Still not ok
    [build] no need to prefix audioCodec now
    [build] Also install mpeg demuxer template as .h
    [build] more shuffling files around
    [build] Better install of files needed to build plugins
    [build] Modular build, part2, still broken
    [build] modular
    [i18n] More german translation by eumagga0x2a
    [i18n] Make more string translatable (eumagga0x2a)
    [all] Remove old cruft
    [QT] Fix menu shortcut (eumagga0x2a)
    [i18n] german update by eumagga0x2a
    [UI] update menu
    [Render] Only resize when something has changed
    [vdpau] Be less verbose
    [misc] Cleanup + refresh UI after executing script to make sure we are not in a non reachable zone. That could trigger an assert
    [Qt] 2nd part of display tweak for time
    [UI/QT] increase digit size (eumahha0x2a)
    [UI] Workaround resizing
    [editor] cosmetic
    [editor] Add comments
    [editor] Cosmetic
    [editor] Try to not drop bframes that will be used later as reference (h264/h265 in copy mode). Experimental, that can cause problems
    [cli] fix build, should be done in a cleaner way
    [build] Add rebuild option by eumagga0x2a
    [build] Dont build vdpau, xv etc... when target is cli
    [SDL] fix new style probing
    [Qt] Remove extra ()
    [main] Fwd declaration of vd6_cleanup
    [merge]
    [cleanup] Move things around
    Merge pull request #16 from ajschult/vd6_cleanup
    Call ADM_vd6_cleanup on shutdown
    [main] Cleanup, part2
    [main] Cleanup code
    [audioDevice] Dont delete stuff when the underlying dll has been unloaded
    [Qt] Change signal from activated to triggered
    [All] Change onexit management + some memleaks
    [All] Try to exit in a cleaner way, to avoid fight between Qt and ADM
    [demux/mkv] Ignore most of PTS with VC1, they are sometimes wrong
    [core] Add VERY simple frame extraction for VC1
    [build] Add a simple build script on ubuntu
    [ass] Fix typo
    [UI] Add fwd/bwd by one mn
    [UI] Tweak icon
    [UI/Qt] add new icons
    [UI/Qt] Add button and actions for fwd/bckwd 1mn
    [Ass] Fix clipping of out of bound bitmap
    [partial] Better management of boundaries, slightly slower
    [nsi] Add audio device plugin
    [Render/GUI] Fix win32 compilation
    [Preview] Fix declaration to avoid circular deps
    [QT] Make sure we dont keep using stuff being destroyed
    [Qt] Better management of redraw
    [msharpen] Fix show mask
    [nsi] Fix path
    [nsi] Add shader
    [glShader] Add and install demo shaders
    [render] Make a copy, using a shallow copy is unsafe
    [partial] User interface
    [Prefs/couple] Add std::string in addition to char *, safer
    [partial] Proper management of params
    [UI] oops, that should crash
    [partial] Mark a lot of filters as partilizable
    [partial] Fix off by 1000
    [partial] Fix tag position + parameters for partialized filter
    [partial] fix parameters
    [partial] Small fixes
    [partial] Step 2
    [build] X265 be slightly more verbose when we fail to detect a working x265
    [build] Cosmetic, fix optional component build when the status is True instead of 1
    Merge pull request #14 from ajschult/abs_unsigned
    Merge pull request #15 from ajschult/max_unsigned_int
    Explicitly cast to unsigned int
    Cast to int so we can take abs()
    [partial] Going fwd, still not working
    [filter] Fix new method handling in plugin
    [partial] Add missing function
    [partial] Groundwork to be able to partialize some filters, not all
    [x264/x265] use default copy operator, being a smart ass just leads to crash
    [x264*] Change NULL to empty std::string
    [x264/x265] update to std string
    [avsFilter] update to std::string
    [core] update json with std::string
    [Ass] update param type to std::string
    [all] Change parameter from char * to std::string, it is safer
    [avsFilter] Fix compilation (untested)
    [glShader] make a memleak rather than a crash (attempt)
    [Misc] Change prototype for fileSel, dirSel from char * to std::string, that may cause bugs (a lot)
    [fileSel/Qt] Cleanup
    [shaderLoader] Use load from buffer instead of load from file, to avoid problems on win32commit
    [All] Add load/save default settingscommit
    [Gl] Add shaderLoader plugin as regular video filter
    [shaderLoader] Tweak a bit shader3, add Pts uniform value
    [plugin] Add a openGl demo plugin, pretty useless as it is
    [cpuCap] Reindent + cap the range so that we dont have signed/unsigned issues
    [nsi] No cli for videoEncoder
    [NSI] Also install cli & qt5 version
    [merge]
    [nsi] simplify installer + also install dev files
    [Qt/build] Install some headers so that qt plugins can be compiled standalone
    [Core/OpenGl] Force gcc/clang NOT to optimize hand written assembly, it messes things up
    [openGl] Prevent compiler from optimizing too much by marking the var as modified
    [Build] Tweaks for new win64 compiler
    [core/getbits] Revert last patch, not enough
    [build] Try to workaround compiler bug, looks like that one https://gcc.gnu.org/bugzilla/show_bug.cgi?id=60902
    [TS/demux] Try not to crash when no video frames are present
    [Win64] Try to workaround the win64 bug when using getBits
    [build] Use gcc or clang for Xcompilation (win64)
    [core] Check get_bits boundaries
    [H264] Make parsing more robust
    [Cli] Propagate simpleRender changes
    [Qt4] Unline interface of ADM_Qvideo
    [Qt] Optimize simple render, avoid memcpy
    [Qt5] Reshuffle the redraw management code to avoid copying things over and over
    [VDPAU] Workraround, do not even try if colorspace is not yv12
    [editor] Workaround bad display of first frame on interlaced content
    [logo] Disable alpha spinbox when image has an alpha channel
    [annexB] Fail nicely when splitNAlu has a problem
    [imageLoader] Take the right channel for alpha
    [Qt/Working] Slightly better management of cancelling a working dialog window
    [Save] Cancel encoding if pass1 was cancelled
    [logo] Fix some ui bugs
    [logo] UI tweaks around alpha
    [nsi] fix typo
    [install/nsi] update nsi to propgate logo filter changes
    [logo] Cli version
    [logo] Ui tuneup
    [logo] Cleanup
    [logo] getting there
    [ADMimageLoader] copy from branch 3.02
    [imageLoader] Improve colorspace compatibility
    [core] rebase yuv444 10bits patch
    [oops] Revert last patch
    [plugin/vdpau] Propagate changes
    [Qt] Dynamically alloc QTranslator, they are being freed at exit
    [build] Fix parallel build of lav* by splitting targets and adding dummy dependencies
    [videoFilter] Remove debug mode for ivtcDupeRemover + change defaults
    [core] Image diff, mark them as output, maybe enough
    [core] Image diff, mark register as clobbered
    [Installer] add ivtcDupeRemoval, remove decimate
    [ivtcRemover] Fix CmakeLists
    [videoFilters] Add ivtcDupeRemover instead of Decimate
    [core] Reindent
    [core] Image diff : Process 8 bytes at a time
    [cosmetic] reindent
    [CoreImage] Proper use of stride for core utils
    Merge pull request #12 from knowledgejunkie/gui-error-consistency
    [VS] add std=c++11, else it does not build
    [VS] Fix build with newer vapoursynth
    [Demuxers] Disable vapoursynth, better to use vsproxy
    [cosmetic]
    [AudioBridge] Fix casting error when seeking is not accurate (AAC/...)
  4. #234
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.14
    Code:
    : Fixing bugs and polishing. For WIN32 only, YOU MUST DEINSTALL THE PREVIOUS VERSION FIRST.
    i18n:
    * A lot more is now translatable (D. Amm)
    * Hungarian translation (rezso)
    * German translation update (euma)
    * French translation update
    * PT/BR translation partially fixed
    * Dannish translation update (scootergrisen)
    Platforms:
    * Qtx : Automatically check if a new version is available once a day
    * WIN32 : Reverted to MXE cross compiler, XP now works again
    * OSX : Fixed the packager, it should work every time now (no more borked dmg)
    Application:
    * Decoding : Deal with corrupted stream in a nicer way (H264/TS)
    * Decoding : Enable lagarith
    * Decoding : Support for flac through libavcodec
    * VDPAU : Try harder to release resources at exit
    * Demuxer : Image loader improved and cleaned up, more jpeg formats are supported
    * Editor : Try to deal better with corrupted audio in copy mode
    * TS : Add support for new EAC3 identifier such as the ones used by numericable / DVB-T
    * Encoder : Fix most of the libavcodec based encoders
  5. #235
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.15
    Improved hardware decoding / encoding and usability bugfixes.
    Make sure you enable hw accel and use the matching display (dxva2/dxva2 for windows). If you can use the win64 version, it works better.
    Code:
    * Hw Accel : Fixed nvEnc and added simple nvEnc-HEVC (windows/linux)
    * Hw Accel : Added support for HEVC/VC1 with libVA (linux)
    * Hw Accel : Experimental Dxva2 video decoder + Dxva2/D3D display engine (windows)
    * Demux : Mpeg TS, fix non multiple of 16 file management (euma)
    * Audio/win32 : Fixed CPU consumption when playing audio
    * Editor : Fixed copy /paste /delete /undo (euma)
    * Editor : A *lot* of seeking bugs fixed (euma)
    * Editor : A *lot* of marker management bugs fixed (euma)
    * Audio : Added FDK-AAC as encoder
    * x26* : Added a "None" preset
    * x265 : Fixed 2 pass encoding on windows
    * i18n : Qt4 vs Qt5 language fix (D. Amm)
    * i18n : German translation updated (euma)
    * UI : Added reload default settings (euma)
    * UI : Allow minimizing to tray while encoding (euma)
    * OSX : Update to Sierra
  6. #236
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.16
    Code:
    [installer] update what s new
    [contrast] dont autoscale histogram
    [filter] misc tweaks
    [vaapi] Put the filter in the QT section as we use vaapi with X11 only
    [vaapi] wrong color conversion support
    [vaapiFilter] mostly working resize
    [vaapi] more background work
    [vaapi] Skeleton for vaapi resizer
    [flyDialog] only allow multiple of 0.5 zoom up and down + cache the zoomed value
    [videoFilter/contrast] improve UI
    [flyDialog] Dont use QStringLiteral
    [flyDialog] begin factorizing
    [flyDialog] Generalised Auto zoom, part 1
    Merge pull request #63 from eumagga0x2a/window-width
    [flyDialog] first pass done
    [Qt] Take actual dimensions of widgets into account when resizing the main window
    [flyDialog] spread more
    [flyDialog] spread the good stuff
    [flyDialog] move toolbox buttons to flyDialog
    [flyDialog] sort of fix autoZoom
    [flyDialog] better playback
    [flyDialog] Dont use things that belong in derived class from the base class
    [flyDialog] the currentPts belongs to flyDialog, remove dirty hack
    [core/ffmpeg] Backport nvenc not requiring nonfree flag from ffmpeg 3.1
    [ffmpeg/patch] Backport patch from 3.1 ffmpeg branch about nvenc not requiring non free. Since it is possible due to the MIT licensing of nvenc header, it should applies to all branches
    [flyDialog] proper export
    [flyDialog] merge the 2 flyDialog files
    [flyDialog] cleanup
    [flyDialog] simplify more
    [flyDialog] Simplify
    [all] Move flyDialog to be Qt only
    [plugin/flyDialog] simplify, move the flyDialog to Qt only part
    [bootStrap] remove gtk
    [plugin] remove gtk
    [flyDialog] cleanup
    [build] move flyDialog to Qt only to simplify it later
    [core/flyDialog] cosmetic
    [UI/QT] auto zoom preview window
    [filter/preview] Bump api version + make playback stop on error
    [Qt] Skeleton for backward/forward 1mn
    [Qt] cosmetic
    [Qt] Slightly better filter preview window
    Merge pull request #62 from eumagga0x2a/i18n-minimal-fixes
    Merge pull request #61 from eumagga0x2a/selection-widget-cosmetics
    [i18n/de/ru] Add kb accels to the audio track dialog, add a missing translation and fix agreement in i18n/ru
    [Qt] Reduce the minimum width of the selection widget
    Merge pull request #60 from eumagga0x2a/vdpau-decoder-to-upper
    [cosmetics] Show an uppercase string as decoder name for VDPAU
    [libva] Export defines and flags from core
    Merge pull request #59 from eumagga0x2a/build-with-external-libs
    [build/plugins] Fix build with external libs (oops...)
    Merge branch 'master' of github.com:mean00/avidemux2
    [va/encoder] reindent
    [va/encoder] Better initialization
    [va/encoder] helper functions
    Merge pull request #58 from eumagga0x2a/seek-by-time
    [UI] Move a variable declaration in GUI_lastFrameBeforePts where it belongs
    [Ts/Demux] probe deeper to see if wanted audio track is there
    [core/vs/import] Also import the dxva2 header files
    [clock] re-indent + simplify
    [cosmetic] Remove tabs
    [qt] increase buffer to avoid stack overflow (1st bug found with vs)
    [build] Better management of coreConfig
    [core] Reenable dxva when compiling with vs, not fully working yet
    [build] More vs2015 fix
    [Qt] Fix openGl build on vs2015
    [all] Try to avoid defining STDC all across the code
    [build/openGL] Add missing glext.h file
    [Qt] Proper dll linkage declaration, fixes a lot of warning (vs)
    [filter] fix prototyping so it compiles with vs
    [build] tweak a bit build so that ffmpeg builds with vs nicely
    [playback] Dont busy loop when there is no audio track
    [demuxer] Fix plugin export (vs)
    [demuxer] dont use the stack too much, it crashes on VS
    [filte] Fix and re-enable avsfilter (fahr)
    [build/json] try to be compatible with mingw64 x2
    [x265] Only deal with recent (>1.9) version of x265 that supports utf8
    [plugin/demux] Fix symbol export for vs
    [build] Fix video encoder plugin for vs
    [core] fix bad ifdef
    [build] Export needed symbols for plugins (vs)
    [build] fix redirect output + engine dll loading + list folder content
    [Core] More vs fixes, alignedAlloc + list folder
    [build] more vs fixes for plugin
    [demux/avi] Fix packed keyword for gcc
    [plugin] Fix audioencoder / lav
    [core] Add missing export files
    [plugin] fix most of the plugins for VS
    [main] Try to cope more gracefully with non working tinypy engine
    [all] Factorize alloca vs _alloca + some auto cosmetic stuff, damn atom
    [audioEncoder/avcodec] Change the way we create multiple plugin from one file
    [plugin/vs] Fix some VS compilation issues
    [build/qt4] Factorize
    Merge pull request #50 from eumagga0x2a/ubuntu-build-script
    [vs/qt] Fix wrong libs to link with (oops)
    [vs/qt] Also link to Qt5WinExtra
    Merge pull request #45 from TotalCaesar659/master
    Merge pull request #46 from eumagga0x2a/default-audio-device
    Updated Russian translation
    [Pref] Return false if loading config fails, avoid selecting dummy audio device in this case
    [Qt] Vs compilation fix
    [win32] Dont look at dxva2 at all with vs for the moment
    Merge pull request #44 from eumagga0x2a/ffmpeg-git
    [Core/ffmpeg/vs] Partially install ffmpeg libs (actual dll are missing)
    [Qt/vs] Make it compile
    [Build] Fix archiving ffmpeg git checkout
    [Build] Fix ffmpeg checkout from git as fallback
    [osx] Set fontconfig so that libass works
    [core/vs] disable dxva2 for the moment, we are using a mingw version
    [build/core/vs] More compatibility fix
    [win32] Remove more duplicate
    [win32] Remove duplicate functions
  7. #237
    Erklär-Bär Avatar von LigH
    Registriert seit
    19. April 2003
    Ort
    OPAL-Invalidengebiet Altmark
    Alter
    42
    Beiträge
    42.345
    Kurz hintereinander zwei neue Versionen:
    Code:
    2.6.17
    * Allow EAC3 in mp4 and mp4v2 (fiftyplus/euma)
    * Fix behaviour of preview window when video size is ~ screen size
    2.6.18
    * Fixed slider in preview mode
    Auf gute Zusammenarbeit:
  8. #238
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.19: General UI polish by euma, better support for HEVC in mpeg TS
    Code:
    * Filter : All filters with preview have better navigation dialogs
    * Filter : Delogo filter UI redone
    * Filter : Fixed changeFps/resampleFps seeking
    * TS/Demux : HEVC support improved
    * Flv/Demux : Support large files (euma)
    * Audio : Allow EAC3 as external audio track
    * UI : General usability cleanup (euma)
    * UI : Allow using the last read folder as default save folder (euma)
    * UI : 2 pass encoding dialog cleanup (euma)
    * UI : Dynamically enable/disable menu (euma)
    * UI : Customizable keyboard shortcut (euma)
    * UI : Allow reverting page up/down (euma)
    * Codec : Better support for 10bits
    * i18n : Russian translation updated (TotalCaesar659)
    * i18n : Greek translation updated (nikoss)
    * i18n : General cleanup (euma)
    * Updated ffmpeg libs to 3.0.7
  9. #239
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.20
    Code:
    Core: The bundled FFmpeg has been updated to version 3.0.7
    Core Encoder: A crash encoding MPEG-2 with B-frames disabled has been fixed
    Core Encoder: An error due to invalid decoding timestamps at the end of encoding with MPEG-2 has been fixed
    Core Audio: Sound issues including audio dropouts with AAC in MPEG TS fixed
    Core Audio: External AAC audio misidentified as E-AC3 fixed
    MKV Demuxer: FPS calculation improved
    MKV Demuxer: A crash with audio tracks using lacing extensively fixed
    MKV Muxer: The FPS value is set correctly now
    FLV Demuxer: File kept open preventing deletion fixed
    VPX Decoder: Swapped colors fixed, support for VP9 added
    macOS: Passing command line arguments to the application fixed
    VDPAU: Decode MPEG-1 instead of crashing
    Qt / Properties Dialog: A button to copy the data to clipboard added
    Qt / Filter Manager: Dynamically disable not applicable context menu entries in the list of active filters
    Qt / Filter Manager: Horizontal scrolling in the list of available filters eliminated
    Qt / MPlayer eq2 Plugin: The sliders on the right becoming squeezed horizontally fixed
    UI: File dialog not adding a file name extension when saving projects fixed (not in 64 bit builds for Windows yet)
    i18n: Russian and German translations updated (TotalCaesar659 / eumagga0x2a)
    Debug: Avidemux now prints the correct version string to the console or to the application log
  10. #240
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.124
    2.6.21
    Code:
    win64 build issue
    The x265 encoding plugin was broken on win64 and regenerated. No other change.
    Win32 are still 2.6.20
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. VirtualDub(Mod)(MPEG2) - aktuelle Versionen
    Von Rippraff im Forum News
    Antworten: 135
    Letzter Beitrag: 1. April 2017, 16:30
  2. BSPlayer - Aktuelle Versionen
    Antworten: 44
    Letzter Beitrag: 10. November 2015, 16:32
  3. Antworten: 43
    Letzter Beitrag: 12. September 2015, 21:44
  4. Avidemux Scripting
    Von dsiggi im Forum Video-Bearbeitung & Frameserving
    Antworten: 2
    Letzter Beitrag: 16. July 2006, 15:28
  5. ImgTool Classic/Burn - Aktuelle Versionen
    Antworten: 51
    Letzter Beitrag: 2. March 2006, 10:06
Stichworte
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
