Hey guys,
Here's a new release of mkvtoolnix, 1.8.1. It's a minor bugfix release, no new features.
Here's my usual link list:
the home page:
https://www.bunkus.org/videotools/mkvtoolnix/
the source code:
https://www.bunkus.org/videotools/mkvtool...x-1.8.1.tar.bz2
Unicode enabled binaries for Windows 2000/XP and newer:
https://www.bunkus.org/videotools/mkvtool...1.8.1-setup.exe
Windows 9x/ME binaries:
Binaries for various other Linux distributions are available from the program's home page.
The changes since 1.8.1:
2006-11-25 Moritz Bunkus <moritz@bunkus.org>
* Released v1.8.1.
2006-11-24 Moritz Bunkus <moritz@bunkus.org>
* mmg: bug fix: Some input controls (like "subtitle charset")
where disabled for appended tracks even though the user can and sometimes has to change those settings. Fixes Anthill bug 216.
2006-11-19 Moritz Bunkus <moritz@bunkus.org>
* configure: new feature: Allow the user to tell configure which "wx-config" executable to use ("--with-wx-config=...").
2006-11-14 Moritz Bunkus <moritz@bunkus.org>
* mmg: bug fix: The "aspect ratio" box was losing its input when the user switched tracks.
* mkvmerge/mmg: new feature: If ATDS AAC tracks are added to mmg and the AAC track's sample rate is <= 24000 Hz then mkvmerge and mmg assume that the AAC is a SBR track and mmg will check the "AAC is SBR" checkbox automatically.
2006-11-12 Moritz Bunkus <moritz@bunkus.org>
* mkvmerge: bug fix: Quicktime/MP4 files with AVC video tracks and missing CTTS atoms caused mkvmerge to crash after the recent changes to the Quicktime/MP4 timecode handling.
* mkvmerge: bug fix: Fixed a segfault if the file specified with
"--attach-file" does not exist. Bugfix for Anthill bug 213 and
Debian bug 393984.
* mmg: bug fix: Fixed a crash on loading XML chapters after having saved XML chapters.
2006-11-11 Moritz Bunkus <moritz@bunkus.org>
* mmg: new feature: Made the "set the delay input field from the file name" feature disengageable.
Have a nice weekend.
Regards,
Mosu
