Seite 17 von 18 ErsteErste ... 715161718 LetzteLetzte
Ergebnis 161 bis 170 von 174
Thema: MKVToolnix
  1. #161
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    Standard AW: MKVToolnix
    9.1.0
    Code:
    * mkvmerge: MPEG TS/teletext enhancement: included the teletext page number in the JSON/verbose identification output as track property "teletext_page".
    * mkvmerge: MPEG TS bug fix: the "text_subtitles" property of the JSON/verbose identification modes was always set to true for all subtitle tracks, even for those that aren't text subtitles (VobSub, PG).
    * mkvmerge: MPEG TS/teletext enhancement: if a teletext track contains multiple teletext pages then mkvmerge will now recognize all of those pages as separate tracks to merge instead of only merging the first page. See #1662.
    2016-04-21 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPEG TS/teletext enhancement: mkvmerge will now ignore obviously bogus PTS values for teletext tracks and use PTS from earlier audio or video packets instead. See #1662.
    2016-04-20 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPEG TS/teletext bug fix: the language code signaled in the MPEG TS PMT is taken into account when selecting the character encoding to use during decoding of the teletext subtitles, not just the "national character set" stored in the teletext page headers. For example, a German teletext page may signal "national character set" 0 (English) whereas it's actually 4 (German). See #1662.
    * mkvmerge: teletext decoding bug fix: fixed dropping of certain non-ASCII characters in rare circumstances due to wrong filtering of already UTF-8 encoded strings.
    * mkvmerge: MPEG TS reader enhancement: teletext tracks of type 5 (hearing impaired) are recognized as subtitles, too. Implements #1662.
    2016-04-16 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: characters that aren't valid in path names are automatically removed from the output file name. Implements #1647.
    * MKVToolNix GUI: bug fix (Windows only): the GUI didn't start if the USERNAME environment variable contained characters that aren't allowed in file names (e.g. : or ?).
    2016-04-13 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: AVI reader bug fix: fixed reading files where the file ends in the middle of an audio chunk. Fixes #1657.
    2016-04-11 Moritz Bunkus <moritz@bunkus.org>
    * mkvextract: new feature: added support for extracting WebVTT subtitles. Implements the extraction part of #1592.
    * mkvmerge: new feature: added support for reading WebVTT subtitles from WebVTT and Matroska files. Implements the merge part of #1592.
    * mkvmerge: enhancement: when reading Matroska files not created by mkvmerge that contain chapters the existing edition UIDs and chapter UIDs are removed and random ones created. This is necessary as not only HandBrake but other tools assign sequential numbers starting at 1 for each file. Therefore there are two chapter entries with the UID 1, two with the UID 2 etc. and those should, strictly speaking, be treated as if they were a single chapter whereas the user expects those entries to stay separate entries.
    2016-04-09 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: new feature: added an option in the preferences ("Merge" ? "Output") for controlling whether or not the GUI clears the "output file name" input upon removal of the last file.
    * MKVToolNix GUI: new feature: added an option in the preferences ("Merge" ? "Default values") for controlling whether or not the GUI clears the "file title" input upon removal of the last file.
    * mkvmerge: bug fix: mkvmerge will no longer abort reading a Matroska file with a structural error right before the first cluster. Fixes #1654.
    2016-04-03 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: enhancement: added the muxing date in both local time zone and UTC to verbose/JSON identification outputs (keys "date_local" and "date_utc", formatted after ISO 8601) when identifying Matroska files.
    2016-04-02 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: enhancement: added the minimum timestamp for each track in verbose/JSON identification outputs (key "minimum_timestamp") when identifying Matroska files. At most the first ten seconds are probed; if no block is found for a track within that range then the key is not output for the track.
    Also added "muxing_application" and "writing_application" to the "container" section of the output. Currently those are only set for Matroska files.
    2016-03-31 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool change: attachments from source files have been moved from the "Tracks, chapters, tags and attachments" list on the "sources" tab to a new list on the "attachments" tab. That way all existing attachments and all the ones to newly add will be shown in a single tab. This makes it easier to decide which attachments will have to be added and which can be removed.
    * MKVToolNix: merge tool bug fix: when adding playlists the GUI won't ask the user whether or not to scan if there's only a single playlist in that directory.
    2016-03-29 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: AVC/h.264: fixed handling of interlaced frames with bottom field first.
    * MKVToolNix GUI: bug fix: fixed huge memory consumption (e.g. allocation of 2 GB for a JSON file of 650 KB) in the JSON library by updating said JSON library. Fixes #1631.
  2. #162
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.2.0 "Photograph"
    Code:
    2016-05-20 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: the action "select all attached files" in the popup menu actions for the attached files view has been split up into "enable all attached files" and "disable all attached files". Implements #1698.
    2016-05-15 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: bug fix on Windows: removing the drive letter does not cause the colon to be removed automatically anymore. Fixes #1692.
    * MKVToolNix GUI: merge tool bug fix: it's no longer possible to select "1" as the maximum number of files to split into as mkvmerge doesn't accept that value. Fixes #1695.
    * mkvmerge: bug fix: the "interval" chapter generation mode was always creating one chapter too many.
    * mkvmerge: bug fix: if a certain number of chapters had been generated with --generate-chapters then mkvmerge wasn't replacing the void placerholder with the actual chapters. Fixes #1693.
    2016-05-14 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool bug fix: the track column "default track in output" wasn't taking into account if the track had its "default track" flag set to "no" in the source file. This would result in the column showing "yes" in certain situations even though mkvmerge would assign "no".
    2016-05-06 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: fixed detection of (E-)AC-3 in MPEG TS files with unusual stream types (e.g. 0x87) but with (E-)AC-3 PMT descriptors. Fixes #1684.
    2016-05-05 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge, mkvextract: bug fix: fixed handling of Big Endian PCM with a bit depth other than 16, 32 or 64 bits/sample. Other formats were using the Little Endian codec ID, but their content was actually not byte-swapped to match it. Now those other bit depths are byte-swapped to Little Endian, too. Fixes #1683.
    * mkvinfo: the change to start the GUI by default on Windows and Mac OS has been reverted. Instead a separate executable (mkvinfo-gui) will be included for those platforms which starts the GUI by default. The newly introduced option "--no-gui" will remain valid but won't have any effect when used with mkvinfo.
    2016-05-04 Moritz Bunkus <moritz@bunkus.org>
    * mkvinfo GUI: enhancement: the window title now includes the file name. Implements #1679.
    * mkvmerge: enhancement: the "bit depth" track header field will be set for DTS tracks from the first DTS core header. Implements #1680.
    2016-05-02 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: the time zone portion of the "date_local" member of the JSON and verbose identification formats contained the time zone's name instead of its offset on Windows due to the Visual C++ runtime's std::strftime not being C++11 compliant.
    Additionally this resulted in errors about invalid UTF-8 strings for locales where the time zone's name contained non-ASCII characters.
  3. #163
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.3.1 "Mask Machine"
    Code:
    2016-07-13 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool bug fix: the GUI v9.3.0 was often creating an invalid syntax for the --probe-range-percentage parameter for mkvmerge due to uninitialized memory. Fixes #1741.
    * Released v9.3.0 "Second Sight".
    * build system: libEBML v1.3.4 and libMatroska v1.4.5 are now required due to several new elements having been specified for Matroska, and mkvmerge uses those elements.
    2016-07-10 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge, MKVToolNix GUI: new chapter generation feature: two new placeholders have been introduced when generating chapters for appended files, <FILE_NAME> and <FILE_NAME_WITH_EXT>. The former will be replaced by the appended file's name without its extension; the latter with its extension. Implements #1737.
    * MKVToolNix GUI: merge tool enhancement: when opening a saved configuration (via the menu as well as via drag & drop) the current tab will be replaced if it is empty ( = in the same state it is in right after creating new mux settings). Implements #1738.
    * mkvmerge, MKVToolNix GUI: added an option for specifying how much of a MPEG PS or TS file is probed for tracks (--probe-range-percentage). Implements #1734.
    2016-07-09 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPEG TS: considerable parts of the module have been rewritten. Due to its convoluted structure didn't buffer PES packets properly before trying to parse the PES header leading to invalid memory accesses in certain cases.
    2016-07-03 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: fixed overly long file type detection in some cases when text subtitle type probing read a lot of data due to there being no carriage returns near the start of the file.
    * mkvmerge, mkvextract, MKVToolNix GUI: bug fix: several fixes to the handling of country codes. The list has been updated to reflect the currently valid top level domain country codes. Deprecated codes such as "gb" for "Great Britain" are now mapped to their updated values ("uk" for "United Kingdom" in this case). Fixes #1731.
    * mkvmerge: WavPack4 bug fix: relaxed the stream detection criteria to only require the major version to be 4 and not to check the minor version. Fixes #1720.
    2016-07-02 Chao Chen <tochenchao@gmail.com>
    * mkvmerge, mkvinfo: new feature: added flags to support the Colour elements in the video tracks of Matroska containers. Users can use those flags to specify the colour space, transfer function, chromaticity coordinates etc. These properties are useful for correct colour reproduction of high dynamic range / wide colour gamut videos.
    2016-07-02 Moritz Bunkus <moritz@bunkus.org>
    * configure: fixed the Qt detection with Qt 5.7.0 which now requires the compiler to be in C++11 mode.
    * build system: libEBML v1.3.4 and libMatroska v1.4.5 are now required due to the usage of new elements introduced in libMatroska v1.4.5. The copies included in the MKVToolNix source code have been updated to those releases as well.
    2016-06-28 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MP4 bug fix wrt. DTS handling: mkvmerge will re-derive parameters such as number of channels and sampling frequency from the DTS bitstream circumventing invalid values in the track headers (e.g. a channel count of 0). Fixes #1727/1728.
    2016-06-27 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: TrueHD bug fix: fixed detection of 96 kHz sampling frequency.
    2016-06-24 Moritz Bunkus <moritz@bunkus.org>
    * mkvinfo's GUI: fix a crash due to wrong usage of referenced temporary objects. Fixes #1725.
    2016-06-05 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: the default track languages to set can now also be set whenever the language in the source file is 'undefined' ('und'). This is now the default and can be changed back to the old behavior (only set if the source file doesn't contain a language attribute) in the preferences. Implements #1697.
    2016-06-04 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: menus have been added to both the "start muxing" and the "add to job queue" buttons. The menus let the user override the preferences regarding clearing merge settings after starting to mux and after adding a job to the queue respectively. Implements #1696.
    * mkvmerge: the warning about not being able to determine whether a raw AAC file contains HE-AAC/AAC+/SBR has been removed. Implements #1701.
    * MKVToolNix GUI: enhancement: all file names are now displayed with their native path separators (e.g. "C:somewhereoutput.mkv" on Windows). Implements #1298, #1456.
    * MKVToolNix GUI: merge tool bug fix: the GUI now takes into account whether splitting is activated when looking for and warning due to existing destination files. Fixes #1694.
    * mkvmerge: bug fix: the parser for the --default-duration argument was wrongfully handling arguments of the form "123/456i" (only this specific syntax and only with "i" as the unit; other formats and units were fine). This is part of #1673.
    Additionally the parser doesn't use the "double" data type internally anymore fixing loss of precision and failing test cases on certain 32bit platforms. This fixes #1705.
  4. #164
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.4.0 "Knurl"
    Code:
    2016-08-16 Moritz Bunkus <moritz@bunkus.org>
    * mkvpropedit: bug fix: mkvpropedit will no longer say that it's writing the changes if only attachment changes are specified and none of the specified attachments can be found.
    2016-08-11 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: chapter editor bug fix: overly long chapter names don't cause the GUI's window to become overly wide anymore. Fixes #1760.
    2016-08-10 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: DTS bug fix: if present mkvmerge will use an XLL extension's sample rate information as the sample rate to put into the track headers. Fixes #1762.
    2016-08-06 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: new feature: added support for reading Apple ProRes video from MOV/MP4 files. Patch by Chao Chen (see AUTHORS).
    2016-08-02 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: when appending files mkvmerge wasn't starting clusters on video key frame anymore for the first and all following appended files. Fixes #1757.
    2016-07-31 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: when adding attachments the GUI will check if there are attachments or attached files with the same name as the file to add. If so the GUI will tell the user and ask for confirmation.
    2016-07-30 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: enhancement: mkvmerge now accepts file names in square brackets for appending files, e.g. "mvkmerge -o out.mkv [ in1.avi in2.avi in3.avi ]" instead of "mkvmerge -o out.mkv in1.avi + in2.avi + in3.avi".
    2016-07-29 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: VP8 in Ogg: fixed dropping the first frame and the timestamp calculation. Fixes #1754.
    * mkvmerge: bug fix: mkvmerge does no longer emit a warning if no comment header packet is found when reading tracks from Ogg/OGM files. See #1754.
    2016-07-19 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: the "select a play list to add" dialog does now contain a column with the number of chapters for each play list found.
    * MKVToolNix GUI: job queue enhancement: dragging & dropping a valid .mtxcfg file (either a full job file or one containing only merge settings without the job properties) onto the job queue window will import the dropped .mtxcfg job into the job queue. Rest of the implementation of #1714.
    2016-07-18 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: dragging & dropping a job queue .mtxcfg file onto the merge tool or using one as a command line parameter to the mkvtoolnix-gui executable will import the .mtxcfg job into the job queue. Part of the implementation of #1714.
    2016-07-15 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool bug fix: the automatic adjustments to the output file name based on the track types selected for muxing and the mechanism for keeping output file names unique had been broken since release v9.3.0. Fixes #1743.
    * MKVToolNix GUI: merge tool enhancement: toggling the WebM mode check box will update the output file name's extension automatically.
  5. #165
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.4.1 "Black Rain"
    Code:
    2016-09-07 Moritz Bunkus <moritz@bunkus.org>
    * Note: most of the bugs fixed on 2016-09-06 and 2016-09-07 for issue #1780 are potentially exploitable. The scenario is arbitrary code execution with specially-crafted files. Updating is highly recommended.
    * mkvmerge: bug fix: AVC & HEVC readers: the readers will now refuse to handle files where the detected pixel width or height is equal to or less than 0. Before this fix the muxing process aborted with an assertion inside libMatroska. Fixes the last test case of #1780.
    * mkvmerge: bug fix: HEVC parser: fixed another invalid memory access (beyond the end of allocated space). Fixes two test cases of #1780.
    2016-09-06 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: HEVC parser: fixed another invalid memory access (beyond the end of a fixed-size array). Fixes several test cases of #1780.
    * mkvmerge: bug fix: MP4 reader: an error message will be printed instead of an uncaught exception when an invalid atom chunk size is encountered during resync. Fixes a test case of #1780.
    * mkvmerge: bug fix: AAC reader: fixed mkvmerge throwing an uncaught exception due to the sample rate being 0. Fixes a test case of #1780.
    * mkvmerge: bug fix: MP4 reader: fixed an invalid memory access (beyond the end of allocated space). Fixes several test cases of #1780.
    * mkvmerge: bug fix: HEVC parser: fixed an invalid memory access (beyond the end of allocated space). Fixes several test cases of #1780.
    * mkvmerge: bug fix: fixed an invalid memory access (use after free) during global destruction phase. Fixes several test cases of #1780.
    2016-09-02 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: using very large --sync values (several minutes) with certain container formats was causing mkvmerge to abort muxing. Fixes #1774.
  6. #166
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.4.2 "So High"
    Code:
    * mkvmerge: bug fix: AVC & HEVC readers: release v9.4.1 contains a change to both readers so that they will refuse to handle files where the detected pixel width or height is equal to or less than 0. This check was wrong in certain cases causing mkvmerge to reject a file as an unsupported file type. This has been fixed while keeping the constraints on width & height having to be positive.
  7. #167
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.5.0 "Quiet Fire".
    Code:
    * mkvmerge, mkvextract: VobSub handling bug fix: mkvmerge and mkvextract will now update the duration stored in the SPU bitsream with the duration from the container level if it differs at least 1ms. Fixes #1771.
    2016-10-15 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: h.264 elementary stream handling bug fix: if mkvmerge ever encounters changing SPS or PPS NALUs (ones where their ID has been encountered before with different settings) in the h.264 then it will prepend all following key frames with all currently active SPS and PPS NALUs. This enables playback from arbitrary key frames even if they require other SPS or PPS settings than the ones stored in the AVCC in CodecPrivate.
    Fixes #1711.
    2016-10-12 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge, mkvpropedit, MKVToolNix GUI: added support for the "field order" video track header element.
    * mkvinfo: added support for the "field order" video track header element. Patch by James Almer (see AUTHORS).
    * mkvmerge: MPEG transport stream reader bug fix: fixed the handling of Blu-ray PCM audio with an odd number of channels by removing their alignment bytes.
    2016-10-10 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPEG transport stream reader bug fix: fixed mis-detection of certain h.264 files as MPEG transport streams.
    2016-10-09 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: WAV reader bug fix: the track properties (channels, sample rate) for DTS and AC-3 in WAV will now be derived from the decoded bitstream headers instead of the WAV file header as the latter is often incorrect.
    * mkvmerge: WAV reader bug fix: fixed detection and merging of DTS in WAV that uses the 14-bytes-in-16-bytes packing method.
    2016-10-08 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: added menu entries that execute the "close", "save settings", "start muxing" or "add to job queue" action for all currently open tabs.
    2016-10-07 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: merge tool enhancement: when dragging & dropping directories the GUI will process all files within those directories recursively instead.
    2016-10-06 Moritz Bunkus <moritz@bunkus.org>
    * mkvpropedit, MKVToolNix GUI's header editor: added options to modify the "muxing application" and "writing application" elements in the "segment information" container. Implements #1788.
    2016-09-30 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: The Ogg/OGM reader did not recognize Opus files with comment headers anymore. This was broken by the fix to not require Ogg/OGM files to have comment headers in v9.4.0.
  8. #168
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.6.0 "Slave To Your Mind"
    Code:
    2016-11-28 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge & mkvextract: added support for HDMV TextST subtitles.
    2016-11-20 Moritz Bunkus <moritz@bunkus.org>
    * mkvextract: VobSub bug fix: mkvextract will add a "langidx" line to the .idx file upon extraction. Fixes #1810.
    2016-11-14 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: multiplexer enhancement: added a column "source file's directory" to the track list. Implements #1809.
    * MKVToolNix GUI: multiplexer enhancement: added an option for selecting all tracks of the currently selected source files in the source file context menu. Inspired by #1809.
    2016-11-07 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: job output tool bug fix: the button for acknowledging warnings & errors wasn't properly disabled when the user used outside methods of acknowledging them (e.g. via the menu or via the job queue). Fixes #1802.
    2016-10-31 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPLS parser bug fix: fixed reading the "in" & "out" timestamps for "play items". This bug resulted in mkvmerge not reading the correct range from the referenced M2TS file under certain rare circumstances.
    2016-10-30 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: mkvmerge was entering endless loops under certain conditions when appending files. This was a regression introduced with the fix to #1774 (using very large --sync values causing mkvmerge to abort).
    2016-10-23 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: new feature: added options in the preferences to only show the list of often used languages/country codes/character sets in their respective selections instead of both the often used and the full list. Implements #1796.
  9. #169
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.7.0 "Numbers".
    Code:
    * Deprecation warning: Several options and features are now deprecated and will be removed at the start of 2018. These are:
    - mkvmerge: the options "--identify-verbose", "--identify-for-gui", "--identify-for-mmg" and "--identification-format verbose". Please convert existing users of these interfaces to use mkvmerge's JSON identification output which can be invoked with "--identification-format json --identify …".
    - all command line tools: the old, proprietary format used for option files. Please convert users of this interface to the new JSON option file format introduced in this release.
    - all command line tools: the option "--check-for-updates" (the GUI will keep its online check for updates, though). There is and will be no equivalent interface in the tools themselves. Users of this interface can switch to retrieving the information about available updates directly from the MKVToolNix website. The information is available as JSON and XML files at the following URLs:
    https://mkvtoolnix.download/latest-release.json.gz https://mkvtoolnix.download/latest-release.xml.gz
    2016-12-26 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: enhancement: added a new track property in JSON/verbose identification mode called "multiplexed_tracks". It's an array of track IDs that describe which of the tracks mkvmerge reports as separate ones were originally part of the same source track (e.g. TrueHD+AC-3 in a single track in MPEG transport streams). Implements #1835.
    2016-12-23 James Almer <jamrial@gmail.com>
    * mkvmerge: added support for skipping APE(v2) tags in TTA files.
    2016-12-22 Moritz Bunkus <moritz@bunkus.org>
    * mkvextract: enhancement: added support for reporting progress in --gui-mode the same way mkvmerge does.
    * mkvmerge: bug fix: when using --track-order without specifying all tracks, the track numbers could end up in a way the user did not expect. Now mkvmerge will always assign track numbers for those tracks that are listed in --track-order first. The other tracks are assigned numbers afterwards. Fixes the second part of #1832.
    * mkvmerge: bug fix: when reading Matroska files the movie title was always taken from the first Matroska source file, even if that file didn't have a title set. Fixes one part of #1832.
    2016-12-19 Moritz Bunkus <moritz@bunkus.org>
    * all: new feature: all command line tools can now read JSON-formatted option files. Such a file's name must have an extension of ".json" (e.g. "mkvmerge @options.json"). Its content must be a valid JSON array consisting solely of JSON strings.
    2016-12-17 Moritz Bunkus <moritz@bunkus.org>
    * build system: building the GUI components of MKVToolNix now requires Qt v5.3.0 or newer.
    2016-12-16 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: header editor & jot output enhancement: added menu entries for saving or closing all open tabs.
    2016-12-13 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: chapter editor enhancement: added menu entries for saving or closing all open tabs.
    * build system: MKVToolNix now requires a compiler that supports the following features of the C++14 standard: "std::make_unique()", "digit separators", "binary literals" and "generic lambdas". For the GNU Compiler Collection (gcc) this means v4.9.x or newer; for clang it means v3.4 or newer.
    2016-12-11 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: MPEG TS/MPLS reader improvements: added support for subtitle tracks that are referenced from the MPLS file as sub-paths in other M2TS files than the main tracks.
    2016-12-08 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: re-worked the startup code not to use lock files when trying to open a socket for communicating with an already-running instance. This aims to prevent situations with stale lock files not being cleaned up and the GUI not starting anymore as a result. This might fix or prevent issues like #1805.
    * mkvmerge: teletext subtitle bug fix: fixed the handling of DVB teletext subtitles signaled with data unit ID 0x02 and that contain pages from multiple magazines.
    2016-12-05 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: multiplexer enhancement: the file identification process has been re-written to be properly multi-threaded. This allows the user to continue working with the GUI while e.g. playlists from a Blu-ray are identified.
    2016-12-03 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: enhancement: mkvmerge can now handle Blu-ray playlists from the "BACKUP" sub-directory of a Blu-ray disc.
    * MKVToolNix GUI: new multiplexer feature: added a menu entry for copying the title to the destination file name. It will replace the destination file's base name but keep its path & extension.
    * MKVToolNix GUI: new multiplexer feature: all positive file identification results will now be cached between runs. This speeds up adding the same file a lot, especially when scanning the same Blu-ray playlists again. Cached results are invalidated automatically with newer MKVToolNix releases or when the source file changes.
    2016-12-02 Moritz Bunkus <moritz@bunkus.org>
    * MKVToolNix GUI: multiplexer enhancement: when the user tries to add one of the main Blu-ray index files (index.bdmv, MovieObject.bdmv) the GUI will automatically scan the Blu-ray playlist files and offer them for selection.
    * mkvmerge: bug fix: files smaller than 4 bytes were wrongly identified as MPEG transport streams.
    * MKVToolNix GUI: multiplexer enhancement: tracks, chapters, tags, attachments not selected for multiplexing will be displayed the same way as other disabled controls. Implements #1819.
    2016-11-30 Moritz Bunkus <moritz@bunkus.org>
    * mkvmerge: bug fix: the MPEG transport stream reader was using an outdated format for the "CodecPrivate" element for HDMV TextST subtitles. This has been updated to the current format which only contains the "dialog style element".
    Existing Matroska files using this outdated scheme can be fixed by running them through mkvmerge v9.6.0 itself or any later release as the old format is automatically converted to the new one when it is read from Matroska files.
  10. #170
    Foren Gott
    Registriert seit
    17. February 2005
    Beiträge
    2.067
    9.7.1 "Pandemonium".
    Code:
    * MKVToolNix GUI: multiplex tool bug fix: under certain circumstances the GUI was creating invalid JSON files when starting to multiplex resulting in an error message ("JSON option files must contain a JSON array consisting solely of JSON strings").
Aktive Benutzer
Aktive Benutzer
Ähnliche Themen
  1. .mkv nach .avi problem mit 25minuten film samt multiplen tonspuren
    Von ZonKus im Forum Alternative A/V-Container und -Formate
    Antworten: 44
    Letzter Beitrag: 24. August 2005, 18:00
  2. mkvtoolnix mit ATRAC3
    Von Eastermeyer im Forum Alternative A/V-Container und -Formate
    Antworten: 37
    Letzter Beitrag: 6. August 2005, 21:36
  3. mkvtoolnix & Matroska+DirectVobSub Problem
    Von Deinorius im Forum Alternative A/V-Container und -Formate
    Antworten: 5
    Letzter Beitrag: 28. September 2004, 16:03
Stichworte
Berechtigungen
  • Neue Themen erstellen: Nein
  • Themen beantworten: Nein
  • Anhänge hochladen: Nein
  • Beiträge bearbeiten: Nein
